Front end noise??
Old Apr 2, 2006 | 05:28 AM
rhz2003's Avatar
rhz2003
6th Gear
Default Front end noise??
I have an '06 Night Train and my brother has an '06 Deuce. Both of us noticed that sometimes when we hit bumps in the road there is a banging sound somewhere in the handlebar/neck area. Anyone else have this problem?
Old Apr 2, 2006 | 05:36 AM
Tiffy's Avatar
Tiffy
Default RE: Front end noise??
Take it back to the dealer to have the front end tightened up. I've heard of this before on another forum I think. It was a minor problem with not preping the bike properly prior to your pick-up. It's a fairly rare occurance I think, strange how both of you have the same problem.
Old Apr 7, 2006 | 02:47 AM
vek74's Avatar
vek74
I have an 02 NT. I have the same noise, but I've gotten used to it. I've had the neck torqued twice at the shop and it only makes the clunk occur slightly less. Hope that helps.
Old Apr 7, 2006 | 07:58 AM
FXST's Avatar
FXST
ORIGINAL: rhz2003
Try a heavier weight oil in the front forks. That usually does the trick.........
Old Apr 7, 2006 | 02:16 PM
fxstcguy98's Avatar
fxstcguy98
https://www.hdforums.com/m_90127/tm.htm
Old Apr 7, 2006 | 11:15 PM
vek74's Avatar
vek74
Thanks guys, guess the dealer is a little behind the curve here. I'll try the torque first, fluid after.
Old Apr 8, 2006 | 02:54 AM
BlueDeuce's Avatar
BlueDeuce
Also there is a little slack in the headlight assembly which makes a clunking sound when riding over bumps.
DanDes67
Jul 31, 2016 11:43 PM
SOCALHD
May 26, 2014 09:47 PM
mang0
Sep 11, 2012 09:19 PM
streeteagle
Jun 4, 2011 08:52 PM
bossgator
Oct 13, 2009 08:31 PM
