Decisions, Decisions…what bars for an FXSTS
I had a PM from a member asking some of the same questions and truthfully, I can't answer them. My nearest guess would be Wild 1 chubby 12.5" APES. All the measurements seem to indicate that.
I can't find a stock number but all the wires are inside. I just went out and took some pics. I made them pretty good size for detail so you'll have to go here to see them:
My Springer Bars
Please excuse my bugs
Those accutronix are nice. My dress shirt sleeve length is 36/37, so I think it wouldn't be a problem.
One thing I did notice....when I took the top off of the risers, one had a spring in it and the other did not. Is that normal?
yes, the knurling is offset for a springer, but my mini tach sits between the risers and hides the exposed knurling on the wideglide bars.
my biggest issue on the SE Springer is the Hydraulic clutch reservior.
the stock 1 1/4" HD bars are tapered at the ends where the controls are, the brake reservior has clearance for the 1 1/4" bars without any problems, but the hydraulic clutch reservior has no clearance.
luckily, the '09 SE springer and SE Fatbob are using a redesigned hydraulic clutch reservior that has the same dimentions as the brake reservior.
so it's going to cost me an extra $150.00 for the new clutch reservior on top of buying new cables and lines.
the reason I'm going with the wideglide bars is because every other mini ape out there has a center width of at least 10", and that looks like crap on the narrow springer front end.
plus the wideglide bars only cost $100.00
