Passing Lights have some Haze
Old Oct 30, 2008 | 08:24 AM
zuma's Avatar
zuma
Default Passing Lights have some Haze
Is it normal to have a little hazing at the top of the lense on my passing lights? The bike is a 2008! It appears to be on the inside.??
Old Oct 30, 2008 | 08:54 AM
krub6t9's Avatar
krub6t9
I have hazing on my 07 heritage and wondering what causes this and anything can be done to prevent it.
Old Oct 31, 2008 | 10:49 AM
Pooh AKA Bear's Avatar
Pooh AKA Bear
Talking Hazing in the lamps
I had the same problem and believe it is moisture/humidity that settles in and when dried up will slowly start to haze the reflectors. I cleaned my lenses with rubbing alcohol and large q-tips, from a medical supply. They are about 10" long with a large cotton swab and can be bent to reach into and swab the entire lens reflector. Difference is night and day!! It is a tight fit, be patient and you will eliminate your haze!!!
Old Oct 31, 2008 | 11:37 AM
ndnhog's Avatar
ndnhog
I made the dealership fix mine under warranty. Hasn't came back yet but I get moisture in my damn fuel gauge that drives me crazy.
Old Oct 31, 2008 | 04:41 PM
edeluxe07's Avatar
edeluxe07
The fuel gauge problem I asked about...they said it was "normal"...go figure
Old Apr 21, 2009 | 08:07 PM
evil_monster's Avatar
evil_monster
Strange guys...mine are sealed beam lights. They're air tight....no hazing here. One's been replaced...(2000 FLSTC) from (I think) tractor supply. the other was from the dealer..says Harley on it (I bought the bike used) but they are sealed...no moisture inside.
Old Apr 21, 2009 | 08:28 PM
Other Sheep's Avatar
Other Sheep
My 07 Heritage doesn't have sealed beams. I had a bulb burn out a few weeks ago and replaced it for about $10. Unscrewed lens and pulled bulb from back. Even the harley manual tells what bulbs to use. Maybe someone replaced yours with other lights?
Old Apr 21, 2009 | 08:32 PM
crazybastid83's Avatar
crazybastid83
It is a mixture of dampness and gas from the halogen bulb.
Old Apr 21, 2009 | 09:41 PM
snip0721's Avatar
snip0721
all the earlier models were oem sealed beam (passing and headlight). most, like myself have upgraded to the halogen set-up. same as the late models, since it is better lighting. lots easier to carry spare bulbs as well. steve
Old Apr 21, 2009 | 09:43 PM
oct1949's Avatar
oct1949
my 07 low beam burned out, Harley does have a number, but its a H4 bulb that is not special to Harley's only.
Closest HD shop is 50 miles away, so I calles our local sports bike dealer 2 miles away and they had same bulb, about 900 miles and its still fine..oh! its 1/3 less than HD's
the lens is also fogging over a little but I didn't try to clean it.. the passing lens seem to be a little also but haven't touched them..
Prot
EVO
47
Sep 18, 2016 08:17 AM
Webdude75
Jul 24, 2016 10:12 AM
inverski
Jun 10, 2010 09:42 PM
grzly
Sep 2, 2007 10:23 PM
larry5h
Oct 11, 2006 02:09 PM
