Springer Ape Hangers
Old Dec 8, 2008 | 04:05 PM
ambientgravy's Avatar
ambientgravy
Question Springer Ape Hangers
What's the difference between most regular ape-hanger handlebars and ape-hangers for bikes with a springer front end? I plan on slapping a set of 16" or 18" apes on my '08 softail custom, and I find myself liking the narrower apes is see in different catalogs, etc. ...BUT, all the narrower ape-hangers seem to be for springers... I don't get it, is the riser-to-bar connection different?
Old Dec 8, 2008 | 05:14 PM
wiseguy2day's Avatar
wiseguy2day
The spread is different. Standard handlebars have a 3.5 inch spread (center to center) and springers have a 4.75 inch spread (Center to center)
Old Dec 8, 2008 | 06:05 PM
ambientgravy
Thankyou wiseguy2day, you mean center to center of the risers, right?
Old Dec 8, 2008 | 09:30 PM
highbars92's Avatar
highbars92
I used to have 18" apes that were 1"diam on my springer when I had the stock risers. I kept stripping the nuts on the risers so I went to the Ness triple tree conversion when I upgraded to the Chubby 20"s I'm currently running.My friend has the 18" Chubby's on his 06 Deluxe and used to have 16" LA Gangsta's on it before.
Old Dec 9, 2008 | 08:01 PM
Budmiester's Avatar
Budmiester
Highbars92, are those Wild 1 Chubbys, W0569? I'm looking for a set of 16" Apes for my 08 XBones. They have the look I want, and it looks like they are internally wired, (a must). Did you do the install yourself? If so, what length lines did you end up having to go with?
Old Dec 9, 2008 | 08:24 PM
highbars92's Avatar
highbars92
They are the W0571 20"s with the W0526 4" risers and W0505 smooth clamp. I had to change the triple tree with an Arlen Ness conversion so I could run the standard bars and not the Springer bars with the wider clamp. I bought all of this from ebay seller lwr821akaak47. They were blems and I got a really good deal on them. They had a couple of nicks but nothing bad enough to not buying them. Me and a friend internally wired the bars. It was a PIA but definately worth it. I see why the dealers charge so much to run them. It took us about 3 hours to wire the bars. You can check with Hill City Custom Cycles as they do sell a lot of Apehanger kits and will probably give you the correct length cables to run. I don't even remember the lengths that we used. Hopefully this will help you.
Old Dec 9, 2008 | 08:27 PM
Deuce Bigelow's Avatar
Deuce Bigelow
I'm looking for the impossible.....
I'm looking for mini apes with a 8.5" to 9.5" rise, 1 1/4" diameter and, here's the kicker....7" to 8" center width.
the reason for the 7" center width is the fact that every set of apes that I have seen so far, especially ones made for springers, have at least a 10" center width, and that looks like sh$t to me when it's on a narrow front end like a springer......
Old Dec 9, 2008 | 08:56 PM
Budmiester's Avatar
Budmiester
Thanks for the info.
Old Jan 31, 2009 | 10:52 PM
thb41's Avatar
thb41
check these out...they make special apes for springers....
really cool product.
http://boulebars.com/asp/Site/photogallery/index.asp
SPRINGER22
Aug 3, 2013 09:44 AM
Skeezmachine
Mar 14, 2013 10:29 PM
Bandit23
Sep 6, 2012 11:11 AM
Coletrain34
Jul 22, 2011 11:31 AM
JimStro16
Mar 1, 2010 06:03 PM
