Started the Tear Down - 95" - CAMS
http://smg.photobucket.com/albums/v6...t=4456d752.pbw
Here is an update. Pulled the Cylinders and Pistons. Also removed the Cam Cover.
The outside Tensioner shows very little wear. Embarassingly I only have about 8k miles on the bike. Hopefully I'll get the Cam Plate and Cams out tomorrow and then start the Bearing replacement to Torringtons.
Here are some quick pictures. The closeups of the Tensioner are blurry, I'll post some new ones.
http://img.photobucket.com/albums/v6...e/IMG_0623.jpg
http://img.photobucket.com/albums/v6...e/IMG_0620.jpg
http://img.photobucket.com/albums/v6...e/IMG_0621.jpg
http://img.photobucket.com/albums/v6...e/IMG_0626.jpg
http://img.photobucket.com/albums/v6...e/IMG_0622.jpg
Mike
NY
Started the tear down today so I can get the Heads out to Big Boyz (Bean) next week.
A little more involved then I expected but I got it done. The Throttle Body bolts were a pain is the A&& to get to and loosen and the Rear Rocker Plate was a pain as well. Also those Head Bolts are really tight, thought I was going bust one of my nuts loosening them..
Here are some pics from today's show.
http://img.photobucket.com/albums/v6...e/IMG_0597.jpg
http://img.photobucket.com/albums/v6...e/IMG_0598.jpg
http://img.photobucket.com/albums/v6...e/IMG_0599.jpg
http://img.photobucket.com/albums/v6...e/IMG_0600.jpg
http://img.photobucket.com/albums/v6...e/IMG_0601.jpg
http://img.photobucket.com/albums/v6...e/IMG_0602.jpg
Bag and Tag....http://img.photobucket.com/albums/v6...e/IMG_0603.jpg
I'll be swapping the CAMs out with the new Roller Chain Conversion. Andrews 37N cams
Pictures as I go...
Mike
I hope I don't mess up. I'm taking my time and reading the manual as I go as well. So far so good.
Mike
Added Slide show. I'll update the Slide Show as I move along with install.
See original post
Great thread. I wish I had your ***** of steel. I wanna cam my bike so bad I cant hardly see straight. I'll be following your thread. THanks for the slide show. Maybe you could post all the "Ah Fawks" and extra $$ you run into? Its not always so much what you know, as it is what you dont ......
Thanks for the slide show,
