Protective tape on fender?
Old Jan 4, 2009 | 04:19 PM
RockyTopRider's Avatar
RockyTopRider
i pulled mine off on my old 06 heritage and it ate the fender up when i put the 2 up seat on. i have been told you can use a mouse pad cut to fit and it won't damage paint.
Old Jan 4, 2009 | 04:29 PM
KumaRide's Avatar
KumaRide
Fender bib, easy on, easy off, only $30. Also protects the fender from me when getting on and off the bike
Old Jan 4, 2009 | 05:32 PM
tk353's Avatar
tk353
i removed mine and stuck it to the bottom of the harley pinion seat in case i use it again. I went to mustang seats and it has rubber feet that wont hurt the fender.
Old Jan 4, 2009 | 06:02 PM
Trout Bum's Avatar
Trout Bum
My fender bib completely covered the plastic, so I left it on. That way I can switch back and forth easily.
Old Jan 4, 2009 | 06:40 PM
Dorkman's Avatar
Dorkman
Fender bib is the best solution. Heat the plastic with a hairdryer, peel, then remove the excess gunk with WD-40. A cheap alternative, after removing the plastic, is wide black pvc tape when you put the stock seat back on. It has more body than the blue painters tape.
bjv11383
Jul 9, 2012 01:58 AM
lionsm13
Feb 17, 2011 11:20 AM
Big_Al47
Sep 1, 2010 07:18 PM
stinkfist
Mar 28, 2008 10:37 AM
christrx
Oct 11, 2007 05:24 PM
