solo deluxe
Old Apr 16, 2010 | 06:19 PM
kiwideuce's Avatar
kiwideuce
nice bikes those deluxes
Old Apr 17, 2010 | 12:54 AM
aasmitty757's Avatar
aasmitty757
6th Gear
Default seat rail
Can you tell me what seat rail that is and does it fit a stock deluxe seat?
Sorry, Found it in another post.
Originally Posted by Mystic
I used the chrome hole plugs from Harley. Part #762. If you prefer black, Part #761. Just push in the plugs and you're good to go. They remove easy too when you want to put your seat or rack back on. If you look under your pillion seat, (under the seat itself) you should see a similar chrome plug that is stored in a little hole designed to hold it in place until needed. This will fit into the bigger hole that is left when the pillion seat is removed. The two smaller holes that are left when you remove the rack are plugged by part #762(chrome)or #761 (black). The rack in my picture is an aftermarket rack. You can sort of see the plugs in the pictures. Believe it or not, the plugs are cheap! I almost forgot. No, nothing will fall off of your bike when you take off the rack and seat.
Last edited by aasmitty757; Apr 17, 2010 at 01:21 AM. Reason: Found it in another post
Old Apr 23, 2010 | 06:51 PM
Dawk Halliday's Avatar
Dawk Halliday
Hi Mystic, sweet ride! I've been looking for that fender rack for a while. Any info on where I may find one would be great. In my opinion there is no comparison with a fender bib and your rack for the solo 'look.
Old Apr 24, 2010 | 09:40 AM
deepblue7's Avatar
deepblue7
I removed the seat and rack, replaced the seat with a seat from Mustang. Left the rack bolts in place, but cut two holes in the frame of the seat for the bolts to slide into. It's not a solo seat. Have pis in my album, check it out
Old Apr 24, 2010 | 07:36 PM
ranger56528's Avatar
ranger56528
here is how mine turned out,clean and simple.
Old Apr 24, 2010 | 08:04 PM
aasmitty757
6th Gear
Default Motherwell rack
Originally Posted by hbarleatherneck
the motherwell rack, listed for the heritage springer is the same rack for the deluxe. . i asked them when i bought mine. they are just too stupid to list all the models that the rack fits.
I thought the same thing but when I tried to order mine they told me it would not fit a Deluxe, but they do have a new one made for the Deluxe. It is a little larger than the one for the Heritage.
Old Apr 24, 2010 | 08:12 PM
Lucy's Avatar
Lucy
Mystic, that really is a nice looking bike!
I have a ’09 Deluxe and want to change it up a bit, I sure would appreciate any info you can give regarding that luggage rack!
Thanks,
Lucy
Old Apr 24, 2010 | 09:07 PM
hbarleatherneck's Avatar
hbarleatherneck
i talked to Kelly Motherwell the owner, when I bought mine 4 months ago. and i was told the springer one is the one that fits. and it fits just fine. i am sure all these guys who are running these are running the same one. any harley fender that is the regular width will work with this rack. not newer fatboys, fxst, fxstb, rocker.
Old Apr 24, 2010 | 09:23 PM
aasmitty757
6th Gear
Default rack
Here is the newest one that fits the deluxe, a little larger diameter tubing on the outside than the previous one. It should look about the same mounted.
http://www.motherwellproducts.com/pr...mwl-175-09.htm
Old Apr 24, 2010 | 10:05 PM
Lucy's Avatar
Lucy
Thanks guys, I sure appreciate the responses!
Lucy
