for what its worth....in my 2000 fb service manualit shows that the front and rear wheels are not in alignment with each other (flstc, flstf =.359 ) (fxst, fxstb, fxsts=.526) (flsts=.320) towards the belt side from the center line. i changed this when i made new spacers ,and machined the caliper boss. dead center now. did this well over 5 years ago, no problems at all (see my post on wide tire kit) why the moco decided to offset the front wheel is anyones guess. i would change the ft. wheel and lower legs and move on. i realize this is'nt what you want to hear, but i doubt that the moco is going to do much about it. hell they wouldnt recall the 1999/2000, (all model twin cam) with the cam bearing isues. im not sure why they would want any offset in either front or rear. seems to me center is where it should be. i wonder if earlier lower legs would be an option. steve
You make a good argument 5 years and no issues, I can't argue with that. Are your wheels dead center on each other? After reading your post I tried to measure the rear wheel and it seems to also be slightly offset to the same side that the front wheel is. The front is offset by about 3/4" and the rear is only approx. 1/4" so your statement seems valid. Now I'm thinking if it worked for you........................
I haven't looked at earlier legs, that might be something to consider also. I was more interested in the 08 model year because the legs are chrome and ready to go.
thanks for your info!
front is dead center between the lower legs. that was the factory set-up. the rear was offset from the factory. bike came stock with a 130 rear tire. i went to a 150 and things were too close for my likeing. the rear is now dead center in the swingarm. like i said earlier, not sure why the offset is there to begin with? i've still got my old (non-chrome) lower legs. i'll be more than happy to take any measurements. these are 41mm tubes, that take a 3/4 inch axle. as far as finding true center of the frame and finding out where everything falls from there....never seemed neccessary. steve
Ride the bike and enjoy it. There are many other HD models that have an offset front tire. It is necessary in order to track straight and accommodate the different rear sized tires. Buying an 08 lower and 08 tire will only make things worse. Your bike will not track straight anymore and your tire will wear unevenly. If you rode an 08, 09 10 fat boy you will also notice some of the have a slight lean not all but some....
My 07 fat boy has the offset front tire and my 79 triumph bonneville has an offset tire. Both ride fine. If you think you are buying a finely engineered motorcycle by shelling out 20 grand for a harley you must be out of your mind. Ride the bike, enjoy it. It won't be the last bike you own.. just make sure the next one is to your satisfaction before buying it.
Just like you, my bike rides fine and I have no complaints. As a matter of fact I'm ok with the offset and I don't lose any sleep thinking about it. The only reason I am asking around is because I'm going to swap out my lower legs for chrome ones..... I figured if I was going through the effort and expense to make the swap then why not find out if I can do something about the offset or if it is even an option to center the wheel. If I could find some info, any info, as to why it is offset so much then I could make an educated decision as to change it or leave it. Maybe I should pose the question.... I'd like to center the wheel on my 07 fatboy can hd tell me WHY I SHOULDN'T?
Regardless, I am happy with the bike and of my 2 cruisers (and 1 rocket) its my fave.... I won't be replacing it any time soon!
Riding it and enjoying it!
I would leave it alone. If you center the front tire your bike will no longer track straight, your tire would wear uneven. If you center your front tire you will need to offset the rear tire.
The only look I hate on my bike are the cut cowbells.
I agree..... its settled! New chrome lower legs for an 07 not an 08! But ya know, if you don't like the cutouts on the cowbells, you can center your front wheel and then you could fix the cutout issue !
Have you read 1Coastie's comments in this forum? He seems to have done the swap and is adament that it is perfect.
It's interesting though, there are some convincing arguments that centering it would have no adverse affect. Maybe I shouldn't read so much lol. I'm sure some body some where out there has tried the swap and just for curiousity at this point, I'd like to know if it worked or if they've swapped back!
I've known about the offset since I first bought the bike and I don't think its a problem, there's a reason it was designed like this. Personally I think it's offset so that when we wash our bikes we can get our hands on the inside of the caliper to clean it real nice like..... not too many other bikes have this nifty feature!
Reason: added cowbell comment
I kind of like the Idea of fixing the cowbells and centering the front tire using the 08 parts but the front suspension for on an 08 is more rigid than the 07 and it is designed not to compress as much.
The first big nyc pothole will compress my front end so much that I am sure I will nic my fender.. if you look at the new fb you will notice that the cowbells would hit the fender if you compress the forks all the way...
I would think that if you centered the wheel, there wouldn't be any issue of the cowbells hitting the fender........ wouldn't centering the wheel give enough clearance on either side of the fender for the tins to slide right by the fender?? Also, if you could actually use the front end off of an 08 without having any alignment issues, all you would do is swap the lower legs so in reality you would have the same ride as you always did.
I looked that the newer model fatboys. I think the clearance is not enough and the cowbells to miss if you bottom out. If you shift the wheel to the left the bike would pull to the left slightly when you're riding.
