Putting Quick Deatch side plates and back rest on a 05 Fatboy
Old Jan 7, 2009 | 05:01 PM
trozenhorse's Avatar
trozenhorse
Question Putting Quick Deatch side plates and back rest on a 05 Fatboy
So I want to be able to switch seats and use a 2 up seat with a back rest and put a back rack on the Fatboy. HD says the rear turn signals need to be relocated with a kit but i cant find a picture of where they get relocated to. I do not want to locate them on the license plate, i just dont like the way it looks. Are there any options? Does anyone have any pictures of options for quick detach and where the turn sigals end up? Help! Thanks Ted
Old Jan 7, 2009 | 05:32 PM
sonar_chris's Avatar
sonar_chris
The HD relocation kit doesent really relocate them. What it does do is change out the wide stalks that hold the signals to a 1/4" piece of tubing which gives the quick detach side plates enough room to work properly. My wife wanted a sissy bar and I didnt like the look of the "relocation" kit from HD. So what I did was buy the Kuryakyn Panacea tail light that has turn signals built in to it and I just removed the rear OEM signals all together.
It was a lot more expensive than the relocation kits but I think it looks a lot cleaner.
Old Jan 7, 2009 | 06:38 PM
tmitchellof PG's Avatar
tmitchellof PG
I went with LED,strut hugging,mini bullets, so I would have clearance for my bags.
Tom
Attached Thumbnails Putting Quick Deatch side plates and back rest on a 05 Fatboy-fat-boy-se-031.jpg
Old Jan 7, 2009 | 08:13 PM
coop57's Avatar
coop57
Pic1 HD relocation kit (Clearance Kit)
Pic2 LED auto gems - look cool but hard to see in the day time
Pic 3 lights added to bags to solve day time issue
Old Jan 8, 2009 | 12:18 AM
trozenhorse
sonar, how visible are the turn signals in the rear stop light for other drivers and ever have a cop hastle you over it?
Old Jan 8, 2009 | 11:00 AM
XARAN's Avatar
XARAN
The new HD relocation kit does not use the round extentions , they now have a kit that uses a stem that is the same look as stock.
Old Jan 8, 2009 | 11:04 AM
XARAN's Avatar
XARAN
You can also modify the side plates to fit without moving the T/S. I have seen a couple threads here to do it withthe HD detachables.
I have a set of Bubbas Brake detachable sideplates and hardware that I modified to work on my 05 Fatty with out moving the T/S.
They are in perfect condition and work with any HD sissy Bar, if your interested they are for sale. PM me and I can send pictures.
Old Jan 8, 2009 | 12:26 PM
Double3's Avatar
Double3
What is involved it "modifying" so you don't have to move the T/S?
I may be interested in these.
Old Jan 8, 2009 | 12:56 PM
XARAN's Avatar
XARAN
You just cut away a littlesection of the rear tabs on the side plates.
I will try to get pictures later of the Bubbas plates that I made work on my bike with out moving the T/S.
There is a thread here that shows it done on the HD Side plates.
Old Jan 8, 2009 | 12:59 PM
anubisss's Avatar
anubisss
I got some mini bullet signals off ebay for $20 and bolted them to the rear of the strut.
