What tools do you carry??
edit...I also keep a air compressor/slime kit I got from target.
But if I think about it, if anything goes wrong with the internal workings of the motor or tranny or drive belt, Im not going to be able to fix it on the road, nor am I going to want to fix it. So that eliminates a lot of Allen and Torx sockets and ratchet wrench etc.
So what kid of things can go wrong that I would want to fix on the road compared to calling AAA on my cell?
Clutch cable unless Im carrying an extra clutch cable, I cant fix this and even if I was carrying a clutch cable, would I want to change it out on the road? Changing a clutch cable on a V Twin is a PITA. Pipes have to come off, tranny side cover has to come off, youre going to loose a little tranny oil too. However, this is doable.
Ditto goes for a throttle cable. First you have to be carrying an extra. Although Im sure you could use the idle cable. So this might be plausible to fix on the road.
So realistically, (now listen to yourself Jack), it seems you only need a small set of tools to tighten or to re-adjust something. Bringing jumper cables is a good idea and of course a tire patch kit including a way to pump up the tire.
But still, AAA and a cell phone and plenty of what ever vice (cigars) you have to keep you busy while you wait for the tow truck seem to be the highest priority tools. Oh and maybe a cell phone charger adapter for your bike might be a good thing to have in case you break down but have no cell juice.
OK, so on my next trip, Ill bring:
My screw driver with multiple bits that includes torx and allen
Pliers, small channel locks, small crescent wrench
10mm wrench for the battery terminals
Jumper cables
Electrical and duct tape. (I wrap a small amount around a popsicle)
Tire patch kit and pump, tire pressure gauge
Small flash light
I always carry a knife
Cell phone
Cell phone adapter for the battery pig tail
Extra cigars
Should weigh less then 5 lbs
