Anyone Not Using A K&N Filter Should Read!!!
Well, now that I got the K&N I can stop thinking again, until it's time to clean and oil it.
Don't think so?
Hold it up to the sun and you can see right through it. I'm also into diesel performance, and NOBODY will run a K&N with a diesel engine. Having said that, high filtration isn't as critical on a Harley as it is on a turbo diesel, and the K&N seems to work good enough, but it ain't great...
Do NOT clean before you have at least 20-30K miles on it. Only when it's covered with a layer of dust and dirt will it provide decent filtering.
Don't think so?
For an 05 Ram turbo diesel:
http://www.knfilters.com/search/prod...px?Prod=E-0776
For an 05 Chevy turbo diesel:
http://www.knfilters.com/search/prod...x?Prod=33-2135
For an 05 Ford turbo diesel:
http://www.knfilters.com/search/prod...px?Prod=E-0780
Hmmmm, now isn't that strange. It's really hard for us dumb people to understand that NOBODY will run a K&N with a diesel engine when SOMEONE is selling them and SOMEONE is buying them. Maybe they are using them to hold them up to the sun to prove how crappy they are!
In fact, nobody who wants their engines to last run them..
Just check on any diesel performance forum, and not some product search..
So many better choices that actually filter air.
AFE, S&B ect.
They (K&N) are available, and I'm sure that there are a few guys like you who don't know what percentages of micron filtration is acceptable, but if I were you and you seem to know the answers, I would run nothing but K&N.
I don't think it makes a tremendous difference on a Harley because they are pretty archaic, but none the less, K&N filters are not that efficient. There just aren't any other filter companies with Harley applications in the mix. I'm forced to run one in my Wimmer..
Run a K&N through a turbocharged diesel engine with 5000 lbs of rail pressure and incredibly tight tolerances, and you'll see things loosen up.
You guys can bash away, I really don't care one way or the other.
I'm just telling you that K&N isn't a step above when it comes to filtration. It's a step down.
If you do, toss it in the trash and try a better name..
