help with installing carlini original t bars...
Old Jan 13, 2009 | 09:30 AM
57RebelRocker's Avatar
57RebelRocker
Default help with installing carlini original t bars...
...got a set of carlini 9" rise original t bars and looking for advice on the best way of pulling wires through bars...can pretty well figure something out but thought I would see if anyone has any helpful hints to make it a good experience instead of a bad one...lol...
Old Jan 13, 2009 | 02:29 PM
mimo's Avatar
mimo
Never myself but I´ve seen it done twice. They use a wire to hook 'em and drive 'em all along the inside of the tube.
Mimo.
Old Jan 13, 2009 | 03:06 PM
mojojones's Avatar
mojojones
I suck a shoestring through the bars with a vacuum, then attach my wires to the shoestring and pull them through. If I run into a bind I just work it back and forth until it clears the bind. The hardest part is making the 90 degree bend into the riser. Also it may help to pull just 2 or 3 wires at a time, then pull the rest.
Old Jan 13, 2009 | 07:31 PM
57RebelRocker
thanks guys bars are expected in Wednesday...I'm hoping to get them done that day...that is if all goes as planned...but I should know better than that...lol
Old Jan 13, 2009 | 07:57 PM
Whatyardwork's Avatar
Whatyardwork
The old mechanics wire works well.Havent done a set of Carolini's but Im a body man of 20+ years and those tailgates will give you fits.Make sure when you wrap the wire you tape it and have the pointy end facing away from the dirrection youre pulling.
JSager89
General Topics/Tech Tips
Nov 30, 2017 01:23 PM
saltlick
Aug 3, 2017 10:06 PM
bekkermatt1989
May 26, 2016 08:11 AM
fuel injected
Jan 18, 2013 11:52 PM
REDROADKING
Apr 27, 2006 10:15 PM
