So in the process of installing the lowering kit (Bolt Kit) I know the preload adjustments got adjusted on each shock.. So and advice on how to get the shocks set at the same preload?
I had the same problem when I did mine,
I just backed the adjuster plates up as far as they would go marked the plate with a sharpie and turned them in an equal number of turns.
unfortunately I do not remember how many turns that was but I do remember
adding preload a second time to get it where I wanted it.
Hope this helps.
