no, but why would you want one? once your set for afr you should be good to go. If you want the afr to be constant setting then get a Thundermax with auto tune and their speedometer with the afr and hp and tq and rpm and speed. this meter only checks one cylinder. I guess if your carburetor it would be ok but you would be better off to pay for a dyno tune and they will rejet the carb.
I use an AFR gauge. Love it. Gives you an inside look to your engines tune. If you make changes to your engine, you can change the tune easily. I use it with powercommander usb3. Easy to customize map for power, mpg.
I ran the ThunderMax Digital Speedo for a while.... It was more of a novelty than anything else... now granted I have an EFI bike...
I would tend to agree with tk353 about getting it tuned...
but then if your like me and like to tinker.... well that's another story!
I was thinking of this one, I like to play with the fuel control a little. A little expencive but works real good. Yes I know a thundermax does it too but takes all the fun out of it http://www.daytona-sensors.com/Twin_Scan2.html
how is that going to read the afr? unless you are talking about buying the kit.
i can play with the afr and timing and other stuff with a thundermax
It's more of a tuning tool than just a AFR meter. just like tuning on a dyno, thats why I said the Thundermax does the same and adjusts automaticly. A friend just installed a t-max on his fatboy and loves it. When I get tired of playing around with maps and stuff, I'll get one too
