Lowering an 07 Deluxe
Old Feb 4, 2009 | 03:08 PM
DeluxeRider's Avatar
DeluxeRider
Default Lowering an 07 Deluxe
What have you guys used to lower your Deluxe's? I've been researching it and just about every kit I see says it will not lower 05-07 Deluxe's (I have an 07). I've been leaning toward the Arlen Ness kit that comes with parts for front and rear w/ shorter kickstand. But not sure if the rear parts have the same issue? Don't want to go with new shocks if I don't have to. And definately don't want to go with an air system ($$$$$$). Any help here would be apreciated (part no. if possible).
Old Feb 4, 2009 | 03:37 PM
aggro_jo's Avatar
aggro_jo
the Ness kit will work fine. your shocks are already lower than the other Softails by an inch that is the only difference. any adjustable lowering kit for an 07 softail will lower your bike.
Old Feb 4, 2009 | 03:39 PM
DeluxeRider
Thanx alot man!
Old Feb 4, 2009 | 06:19 PM
Trailfndr's Avatar
Trailfndr
DON'T buy the HD lowered shocks for a softail. Those are already STOCK on the Deluxe.
The reason they all say not for deluxe, is that the MOCO does not want you to lower it any further, Probably due to some sense of ride quality or some such. BUT you can do it, I did it, it works, and it wasn't difficult. You will need a press to take the shock apart to switch out the studs, but otherwise a pretty easy job.
*** SInce the book says NOT for Deluxe, I was told that MOCO tech's won'tperform this for you. I don't know about where you are, but I was told at my dealer that they cold not do it.
Old Feb 5, 2009 | 09:03 AM
DeluxeRider
Thanks Trailfndr. I got a few presses at work I can use, so I should be set.
Old Feb 5, 2009 | 10:52 AM
57RebelRocker's Avatar
57RebelRocker
have had an arlen ness shorter kickstand on back order since november...told me it would be shipped jan.23 than they told me not until april now
Old Feb 5, 2009 | 10:56 AM
anubisss's Avatar
anubisss
Two words. Air ride.
Old Feb 5, 2009 | 11:09 AM
DeluxeRider
anubisss, your ride is friggin sweet!
I might consider air ride if I didn't have a mile long list of other parts I want. Just can't justify spending over a grand for that, when I can lower it for a few hundred. Leaves a lot left over for other parts.
Old Feb 5, 2009 | 11:11 AM
anubisss's Avatar
anubisss
I understand. It has taken me many years to get my bike to where it is.
Old Feb 5, 2009 | 11:16 AM
DeluxeRider
Angry
Damit! I just noticed all the lowering kits are backordered too. I wonder if the kickstands are holding that up too? WTF?
