Heritage Chrome front end package
Old Feb 7, 2009 | 09:49 PM
  #31
Sleeko's Avatar
Sleeko
Talking
Originally Posted by Softail Girl
I really appreciate the thought but how much fun would that be for ME?????* I love to do stuff like that but I haven't found anyone willing to watch and advise without taking over !I'm thinking of taking the forks apart and if (when) something goes wrong and I get too frustrated, I will call in favors...Was that a good deal or what??? Sorry Keno.
Don't know about all that, but I do know that's one pretty Heritage Softail Classic Softail Girl. Just love the Suede Blue and Vivid Black Combo. Right out of the '07 catalogue.
Old Feb 7, 2009 | 10:09 PM
  #32
jimmers1817's Avatar
jimmers1817
Originally Posted by crazybastid83
OMG! I love all the bad information you pick up from the internet!!!!!!
????? huh
Old Feb 8, 2009 | 07:11 AM
  #33
Mike NY's Avatar
Mike NY
Originally Posted by jimmers1817
That's interesting Mike,
If I understand you correctly you're saying we can skip step 1 of the manual where it says to remove the fork tube plug and pull spring out of slider tube?.
That sure takes a good bit of work and worry out of the process.
Thanks for the tip.
Unless your changing the Springs there is no need to open that part up so yes that is what I'm saying. The manual don't forget is for servicing so they show the complete dissassembly. Just remove the top chrome Fork cover nut and loosen pinch bolt and the whole fork assembley slides out. Just slide it down easy so not to scratch the tube. Once that 6mm bolt is out the rest is cake...
Mike
Old Feb 8, 2009 | 07:15 AM
  #34
Mike NY's Avatar
Mike NY
Your right, it happens often. That's why I always do a ton of research comparing articles and posts to hopefully get the most accurate info. Talk to people that have actually done it and you can get some good advice.
If you see something inaccurate maybe you should comment on that instead of some general comment, that would be a bit more helpful I would think.
Mike
NY
Mike
NY
Old Feb 8, 2009 | 09:28 AM
  #35
tlb's Avatar
tlb
I think it is why I said maybe some else has a better idea. I did not think about it when I said that. When I removed my tubes I could of just removed the top fill cap and slipped them out. I did not even consider it.
It will make her job much easier.
When you did your tubes did you find either of the tubes or pinch bolts lose?
When I took my cover off both pinch bolts were only hand tight. one of the tubes was unscrewed about 1/8 inch.
I at this point unscrewed the tube to make sure nothing was wrong.
at least she knows not to unscrew the tubes and to just take off the caps.
Thanks for pointing it out.
Mike
NY
Mike
NY
Old Feb 8, 2009 | 10:54 AM
  #36
keno's Avatar
keno
Maybe we need someone who has recently changed to the chrome sliders,front, left and right rear back panels and slider covers (cow bells) to give us a step by step list of what is only NECESSARY to do instead of us getting confused by the manual which is showing us how to basically tear down and rebuild the front end. Is anybody up for it? I know I would appreciate it.
Thanks,
Old Feb 8, 2009 | 11:01 AM
  #37
Mike NY's Avatar
Mike NY
Thanks,
I posted a link previously that helped me.
http://groups.msn.com/TODDSHARLEYPIX...eforkswap.msnw
I realize it's a RK but the concept is the same.
Mike
NY
Old Feb 8, 2009 | 11:24 AM
  #38
keno's Avatar
keno
Mike NY, For example is it necessary to slide the gas tank back to unplug the wiring harness, or can I just unplug from the headlight? Seems I've heard conflicting instructions.
Old Feb 8, 2009 | 02:01 PM
  #39
tlb's Avatar
tlb
If you are going to replace the upper tins you have to unplug the harness under the tank. there is no way to slide the plug out of the headlight housing from the front.
Old Feb 8, 2009 | 02:03 PM
  #40
tlb's Avatar
tlb
if you slide the tank back make sure you unplug the fuel line first.
