Heritage Engine(?) noise
Old Feb 17, 2009 | 07:38 PM
rbabos's Avatar
rbabos
Originally Posted by klaybus
Is the 08 Comp any better or as I would expect the same as the 07? Same engine if I'm not mistaken on the 07 & 08...96B?
Thanks,
Clay
The big twin comp is for 07 and up. It would seem the 08 comp is the same as the 07.
Ron
Old Feb 17, 2009 | 08:00 PM
rbabos's Avatar
rbabos
Originally Posted by Gon2far
I've had a vibration in my 07 Heritage since it was new and I brought it into three different dealers five different times. They all told me everythings normal. I had a sales manager take my bike for the weekend and ride it for two hours. He told me the bike does vibrate excessivelly and than I had his service department tell me everythings normal and they could'nt find anything wrong. Thats when I realized my HD warranty and HD service was worthless. At highway speeds 65-75mph the bike will shake your eyes lose and rattle your teeth. One of the many thinks I was looking into was the compensator. However I was waiting for Balance Masters new one for my year softail to come out and did'nt even know there was an HD SE compensator. Did someone say the SE compensator would'nt fit the 07 Heritage.
I recently posted on the harmonic balancer you mentioned, and while it will do more or less take harmonics out it will do very little to stop vibration. It's not designed to do that. Actually with such a short crank it may have no use at all. Google it and read some of the user reports. I was curious about it once as well.
I also doubt very much , even the crappy 07 comp will cause the vibration you mentioned. To get that kind of shake in a B motor, someone forgot to put the chain on the balancers, or sprocket timing has slipped on the crank throwing throwing the weights out of phase or you have considerable crank runout. In my case with the stock comp and the big twin comp the actual buzz is the same with either due to my crappy crank. Where the new comp shines is taming the pulses. Buzz is an up and down motion and the pulses are back and forth sorta.
Ron
Old Feb 28, 2009 | 09:58 AM
Tom_07Heritage's Avatar
Tom_07Heritage
Ron, I agree with you on the issue of the starter bang. I am not a "motorcycle mechanic" but I was a machinists mate in the navy working on hydraulic systems aboard nuclear subs. I have been in the industrial maintenance field for 29 years and am presently employed as a reliablility engineer, which means I identify bad situations and make suggestions for improvments before equipment fails. I work with mechanical and electrical controls, and am considered by my peers to be a "go-to" guy for hard to diagnose equipment problems. None of this is meant to be a brag, just qualification for remarks I am about to make.
I recognize the twin cam starter noise as a condition which has a high probability for causing failure. They just haven't been out long enough for the problem to manifest itself. I also feel that the compensator is probably causing the noise in my engine. Even if it isn't, I am still going to replace it with the upgraded SE part.
After dealing with two H-D service shops I have to say that I am not impressed with their level of technical understanding. I believe that many are trained to follow a laid out set of steps for diagnosing certain problems (like the ones in the service manual) but few have the intuition and natural ability that makes for a truly remarkable technician that can figure out problems based on symptoms that are not on their list.
I also think that they are doing their best, based on their ability and understanding.
I have until sept for my warranty to run out. I guess I'd better check on a warranty extension.
Tom
Old Feb 28, 2009 | 01:01 PM
rbabos's Avatar
rbabos
Tom
You are correct. All will give trouble eventually. There are two failure modes to the unit. First is a weakening spring pack which make the unit loose and rattle, generally accompanied with a reduction in starter knock. Along with this comp effect is lost with more pulsing in the drive line, which some people mistake for vibration. However the stacked components may still be tight from the original bolt torque.
Second form of failure and most common is over time the constant pounding from spring pack compression into the rotor face will cause the metal to compress on the back side of the rotor at the spacer. This loosens the compression of the parts from it's original torque on the bolt. Due to loctite and lack of knowledge the tech will assume it is still tight, but in reality it's not. The rotor will start to impact the splines from engine pulses as well as the extension shaft. A low grade knock like rod knock will appear when leaving a stop light in first. This is a loose rotor. There will be also signs of the extension shaft end that's against the rotor showing signs of fretting at point of contact. You will see many of these indications when you pull it off and inspect it, plus comparing the new and old models the first thing you will say is wtf were they thinking when they designed the stock unit. Not one single part is the same in the new model, as in it's progressive cam loading in ramp design with cam reversed to not use the high wear area of the tips, plus the 3 stage spring pack. While still not perfect in some areas, it should be much more successful in the long run.
Ron
Old Dec 2, 2009 | 07:41 PM
Just Don's Avatar
Just Don
Good information all around. My 05 Heritage with 18K miles started displaying a minor vibration mostly felt at the floorboards or more so just resting a toe on the engine guard. Your giving me good places to check. Thanks
martin10
Oct 13, 2017 05:21 PM
2000softail
Engine Mechanical Topics
11
Jan 26, 2016 04:24 PM
russrudder
Screamin Eagle CVO Models
Sep 5, 2012 05:23 PM
missboy
May 15, 2011 10:25 AM
Tom_07Heritage
Welcome Area Only
22
Feb 9, 2009 08:31 PM
