Front end swap...triple tree problems? Help please
Old Feb 22, 2009 | 10:42 PM
Jinxie's Avatar
Jinxie
Default Front end swap...triple tree problems? Help please
Hi
I am swapping the stock front end out on my 92 FXSTC for an aftermarket chrome. I bought this "complete" front end off ebay. Not sure the brand, but it looks like an Ultima or something from Dennis Kirk, etc. Its a nice looking fron end with hidden axle, etc.
Anyway, here is the problem.
The stem bolt is missing the nut and lock ring, etc. I removed my old front end and the nut has a 1" thread. This front end the stem has a 7/8" thread. The stem is 1" on the bearing so thats OK. Also, my old front end has a hole drilled where the lock plate fits into. This one doesnt. What does it use to lock the nut?
Also, how do I remove the old stem bolt from the old triple tree bottom? Maybe I can re-use that stem.
Thanks for the help. I will see if I can find a link to the front end I have in the meanitime.
Old Feb 22, 2009 | 10:57 PM
Jinxie's Avatar
Jinxie
Here is what I have......
http://www.strictlychoppers.com/stor...51&item_id=141
I bought them used.....I have just what is pictured. The thread size is 7/8"
Thanks again
Old Feb 23, 2009 | 07:01 AM
Puzzled's Avatar
Puzzled
From the description of what you have it sounds like you will need a lock washer that has two tabs on the outside edge of it. One tab gets bent over the top tree and the other around the nut. As for the different size nut, find the correct one and install.
dubepj
EVO
13
Jan 29, 2019 03:56 PM
gleam
Sep 15, 2018 04:58 PM
TUCCI
Feb 28, 2012 08:21 AM
Dan0
Aug 15, 2010 09:35 PM
seano
Apr 6, 2010 03:34 PM
