changing the brake/clutch levers
Old Feb 28, 2009 | 10:42 PM
Alain's Avatar
Alain
Default changing the brake/clutch levers
i was reading the soft tail service manual and the book says you have to drain the fluids in the transmission, give the clutch cable some slack among other things. is it really that difficult to switch out the levers?? i thought it was just a simple swap.
i think i might be looking at the wrong part of the book, it cant possibly be that difficult
Old Feb 28, 2009 | 10:48 PM
fishcop's Avatar
fishcop
Default change levers
I changed the levers on my heritage and only had to loosen the clutch cable, then redo once lever was changed.Brake was a simple swap took me about 30 minutes total.
Old Feb 28, 2009 | 10:54 PM
Alain's Avatar
Alain
that's what i thought but wasn't sure. you loosened the clutch cable by turning the bolt on it right (towards the bottom of the cable)??
Old Feb 28, 2009 | 10:55 PM
crazybastid83's Avatar
crazybastid83
You dont drain the trans fluid. At the clutch cable use a 9/16 and a 1/2 inch wrench. Put slack into the cable. Open up the derby cover, unlock the nut with a 11/16 socket. Turn out with a 7/32 allen head to the left. You will now have plenty of slack. Put your lever on. Then turn with a 7/32 allen (clock wise)until you feel resistance. Then back it out 1/2 a turn. Lock down the 11/16 nut. Then Tihten up the clutch cable, leaving 1/8 inch slack at the lever and perch.
Old Mar 1, 2009 | 01:57 AM
fairplay's Avatar
fairplay
i didnt even have to pull the dernby cover. i usually keep my clutch pretty loose though.
when you do the brake side, be careful not to break your stop lamp switch (that is what you will call it to the parts guy when you break it). I prob changed a dozen levers but still managed to f up the switch. the price you pay talking and working.
Old Mar 1, 2009 | 07:22 AM
tk353's Avatar
tk353
I only had one issue. the clutch lever had a nylon spacer that would curl up and bend in half when I used the clutch lever. the spacer was there to fill in a space that stops wobble. I went to the hardware store and bought a nylon cable clamp and cut it in half and used it in place of the spacer and it worked great. I think they cut the factory spacer just 1/8in short
Old Mar 1, 2009 | 10:52 AM
BTL's Avatar
BTL
On my 08 cross bones, I did the same as fishcop, the clutch lever is the easier of the 2 to change out.
89FLHTC
EVO
11
May 3, 2016 07:34 PM
Terry D Kemp
May 23, 2014 05:28 PM
jackcoke81
Aug 12, 2011 08:13 AM
anubisss
Jan 10, 2008 11:28 PM
COFFESLINGER
Jun 30, 2006 06:35 PM
