lowering ?
Old Apr 24, 2006 | 10:51 AM
1meanmach's Avatar
1meanmach
Default lowering ?
thinking of lowering my 01 how hard is it ive never done it. should i just take it to a dealer?
Old Apr 24, 2006 | 11:07 AM
dert's Avatar
dert
Default RE: lowering ?
Softtail or Dyna?,its easy .You will need a lift..There are many choices.You can go with lowered shocks or extensions that bolt directly on to existing shocks but beware,your ride will suffer if you use these as well as the passengers. Best go with new shocks.HD carries them as well as JP Cycles.If its a Dyna pr Sportster, there are brackets available that go on the bottom of the shocks.,There are also considerations withe these also ,but the cheapest way. There is a co.In Waco Tx that sells brackets that will lower it 2".Most only 1 " .Again,to lower its best to go with lowering shocks..Both types are very easy to install. Do a Google search and you will find an abundance of choices.
Old Apr 24, 2006 | 11:27 AM
1meanmach's Avatar
1meanmach
its a softail the chepest i have seen is what looks like a bolt it cost 89$
Old Apr 24, 2006 | 12:23 PM
dert's Avatar
dert
It is 2 bolts that simply bolt onto ends of shocks and that is about the right price ...
Old Apr 24, 2006 | 03:20 PM
SoftailBrian's Avatar
SoftailBrian
I've got the shocks on my 06' Standard. The ride is i little stiffer, but hey I can reach the ground now. Simple install. I have the front lowering kit, but will have the dealer do that.
Old Apr 24, 2006 | 04:33 PM
1meanmach's Avatar
1meanmach
i think im gonna just do the rear what does the front look like lowerd? so you guy think its pretty easy?
Old Apr 24, 2006 | 04:45 PM
went_postal's Avatar
went_postal
For those with lowering kits already installed...
I have heard about the rear tire bottoming out on speed bumps and whatnot... What about the pegs? Any problems with clearance there? That is my biggest concern when thinking about lowering the bike.
Old Apr 24, 2006 | 04:59 PM
1meanmach's Avatar
1meanmach
yeah x2 on that comment does it drag the pipes? or drag anywhere?
Old Apr 24, 2006 | 09:24 PM
VetteSiNz's Avatar
VetteSiNz
I lowered the front of my Deluxe and it scrape under the footboard and mustache engine guard during tight cornering. I'm planning to lower the rear for about an inch; but I'm still deciding weither to do it or not.
Old Apr 24, 2006 | 09:46 PM
1941ratrod's Avatar
1941ratrod
Use the Ness kit its cheep and easy. If your woried about the soft ride buy a Goldwing or leave it the way it is.
