Front Brake Bleeding Problems
Old Mar 5, 2009 | 06:44 PM
mdjim's Avatar
mdjim
2nd Gear
Default Front Brake Bleeding Problems
I need a little help. I'm finishing up installing my 16" apes and i can't get the front brake to bleed. Everything is free flowing up to the master cylinder. I hae gone as far astaking the brake line off to check the flow coming from the master cylinder. I'm just getting a drip. I'm assuming i have a bad master cylinder.
Old Mar 5, 2009 | 06:51 PM
DyNaBoB's Avatar
DyNaBoB
did you use the correct fluid cuz if ya dont it will make the diaphram swell
Old Mar 5, 2009 | 07:02 PM
mdjim's Avatar
mdjim
2nd Gear
I used the same as i used 2 years ago when i switched everything out to crome and ss
Old Mar 5, 2009 | 07:06 PM
crazybastid83's Avatar
crazybastid83
Open the master cylinder lid, wrap a bungee cord around the brake lever against the bar. Leave it overnight.
Old Mar 5, 2009 | 07:27 PM
Cheesecake's Avatar
Cheesecake
I agree... I also cracked the bleeder screw...
Old Apr 15, 2009 | 02:59 PM
stupid_rope's Avatar
stupid_rope
What purpose does this serve? Like, what's the technical aspect to it?
Old Apr 15, 2009 | 03:07 PM
TIPN8R's Avatar
TIPN8R
It's call "gravity bleeding" and it usually does the trick.
Old Apr 15, 2009 | 03:09 PM
keno's Avatar
keno
Speedbleeder. done in minutes..
Old Apr 15, 2009 | 04:45 PM
LBCDeluxe's Avatar
LBCDeluxe
Default brake bleeding
Bleed it from the master cylinder not the bleeder screw on the caliper.
I just did a handle bar change out with Wild1 chubby 18's and fought with the same thing.
A buddy of mine told me to bleed from the master cylinder at the banjo fitting...believe me it works.....
Old Apr 15, 2009 | 04:56 PM
rubiconMike's Avatar
rubiconMike
I agree... reverse bleeding it is the way to go. I just went through this a few weeks ago.
