Baffle removal
Old Mar 14, 2009 | 08:23 AM
David The Hutt's Avatar
David The Hutt
Originally Posted by PewterHeritage
Is there any up or down sides to removing the baffles out of my 45 mile old heritage? I would like a little more noise out the back (of course) but don't want to mess anything up. I'm going to call the dealer and ask if it will void anything on my warranty. Thanks
wont void warranty, but its a bad idea.
cheaper in the long run to pick up a set of slip ons (cycle shack has a set for under $200. youll be charged 1/2 to 1 hour labor to have them put on)
there are many other slip ons that are even better for $100-$200 more. save your money and go that route is my opinion
Old Mar 14, 2009 | 08:33 AM
Jacobi's Avatar
Jacobi
Originally Posted by robzuc97
Kidding, right? Yes, voids warranty! Best results obtained from doing proper stage 1. Adding new parts will not void warranty as long as the parts do not cause a condition which causes failure.
A warranty is not an all or nothing deal. Doing one thing doesn't "void the warranty" for the entire bike. If you tinker with your exhaust, your warranty would only be void for the exhaust, nothing else. Depending on what you do to the exhaust, it might not even void it there.
-Barry-
Old Mar 14, 2009 | 06:31 PM
tk353's Avatar
tk353
Originally Posted by Road_Clam
Slip-ons simply sound lame IMO and are not worth the money.
yep if they are harley slip ons, rush sound as loud as you want with baffle choices
Old Mar 14, 2009 | 07:46 PM
oct1949's Avatar
oct1949
Rush SO's are really good sounding, won't give the #'s as most 2-1's so again it will be owner choice.
Old Mar 14, 2009 | 07:56 PM
ko4qc's Avatar
ko4qc
I have the SEII slip ons on my 07 FXDB and everyone tells me they sound great...especially when I get on the throttle a bit...not too loud on the bottom end but they really wake up at 3500+...:>)
Old Mar 14, 2009 | 08:55 PM
AlaskaErik's Avatar
AlaskaErik
6th Gear
I'm hearing some good things about the Rush slip ons. If I go with a 2" baffle, will I need to do anything with the intake and the EFI? I have a 2007 Heritage Softail Classic.
Old Mar 14, 2009 | 11:07 PM
WarriorHD's Avatar
WarriorHD
The baffles in the stock mufflers are welded in. The only way to "remove" them is to drill them out. I've also heard of guys hammering them out somehow but it's not something I'd want to do to my brand new Harley. The dealer I go to used to drill the baffles out all the time for their customers but recently the EPA started cracking down on the dealerships doing that so it's kind of taboo. Most dealers won't touch it; Period. Still there are a lot of "do it yourselfers" drilling out their baffles since the can get away with it easier than dealers can.
If I were you, I'd consider going with slip-ons or a nice complete muffler kit; V&H, Hooker, Rush, etc. Probably not the answer you want to hear cause it's not "cheap" but its the right way. And keep in mind if you go with a whole system as opposed to just slip-ons, you will have to free up you intake air flow and adjust the fuel management accordingly. So as some of the guys before me said, you're best bet is doing a Stage 1. In the long run, you're bike will not only sound better, it will run much better and it will run cooler. Good luck.
Old Mar 15, 2009 | 05:58 PM
tk353's Avatar
tk353
if you do rush only the you are fine. if you change other things to make the bike run cooler than yes you need fuel management
Old Mar 15, 2009 | 06:06 PM
PewterHeritage's Avatar
PewterHeritage
I really like the sound of the 2.25 baffles with the rush slip ons. What needs done with the intake and fuel managment??
Old Mar 15, 2009 | 07:14 PM
bloodyhead's Avatar
bloodyhead
anything larger than a 1.75 baffle probaly will need a remap..........just a note you might want to think about.
Rcole
Exhaust System Topics
Nov 17, 2014 06:18 PM
PeteS4
Jul 10, 2013 08:09 PM
WillieC
May 28, 2009 04:57 PM
denimnightster
Jul 29, 2008 11:29 PM
kneichko
Mar 29, 2008 10:20 AM
