Oil Filter Wrench
Old Mar 16, 2009 | 07:50 PM
jd8181's Avatar
jd8181
Default Oil Filter Wrench
i haven't changed the engine oil in my harley since i bought it and i was going to do it over the weekend but i've seen that you have to use a special wrench. i was wondering what i need/what you guys use?? i have a harley oil cooler so a strap wrench won't work.
also i was wondering if i need to put in any extra engine oil since i have the cooler on it??
Old Mar 16, 2009 | 08:00 PM
tombeving's Avatar
tombeving
Harley sells a socket that fits on the end of a 3/8¨socket wrench. As far as the oil cooler, when you change the oil it should take 3.5 qts. Put in 3 qts and run the bike for a few minutes. Ride it till the motor warms up, and check your oil level when the bike on the jiffy stand. Add what you need till you are at the proper level.
Old Mar 16, 2009 | 08:09 PM
RjCapp's Avatar
RjCapp
This doesnt help get the old one off but I use the K&N oil filter that has a nut tack welded onto the filter housing. Then all you need is a ratchet and socket to change the filter next time.
I have also had to drive a screw driver into the oil filter type you have to get it to turn loose.
There is more than one way to skin a cat.
Old Mar 16, 2009 | 08:10 PM
Soft06's Avatar
Soft06
Yup,Yup,Yup....what he said.
Old Mar 16, 2009 | 08:13 PM
jd8181's Avatar
jd8181
how much does the harley wrench cost??
Old Mar 16, 2009 | 08:23 PM
IGOTTASRT8's Avatar
IGOTTASRT8
Too much. Go to your local auto parts store and tell them what you need. It will be much cheaper.
Old Mar 16, 2009 | 08:30 PM
jd8181's Avatar
jd8181
i seen they have difference sizes at the auto parts store. what size do i need to get?? and just cut a hole in it for the senser on the side there??
Old Mar 16, 2009 | 09:01 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
If you don't want to get the HD wrench and don't like the orange K&N. You might like to try doing this trick for a little 'different' look.
https://www.hdforums.com/forum/dyna-...ml#post2883294
Have fun, ride safe.
Old Mar 17, 2009 | 09:04 AM
jknowlton's Avatar
jknowlton
Harley oil filter wrench is $7.95 - 9.95
Old Mar 17, 2009 | 09:54 AM
mke125125's Avatar
mke125125
I use a cap type wrench that I picked up at autozone,no need for a hole in it. just break the filter loose with the wrench and remove it with your hand. mine doesnt even come close to the sensor(2007 deluxe).
