Exhaust valve
Old Mar 22, 2009 | 07:37 AM
j33ptj's Avatar
j33ptj
Default Exhaust valve
There is a valve on the exhaust that would need to be removed when I am installing the Big Radius.
When this is removed it can give error messages on the EFI system, any suggestions on how this can be circumvented?
thnks
Robert
Old Mar 22, 2009 | 07:52 AM
Blk and Chrome's Avatar
Blk and Chrome
Sounds like you are talking of the o2 sensors. They should be able to be installed in the new pipes. If you do disconnect them you will get codes and the eng lite on. The BR pipes have bungs for these sensors and if not using a fuel control that doesn't use the o2's like a PCIII then I wold install them.
Old Mar 22, 2009 | 08:07 AM
j33ptj's Avatar
j33ptj
No this is a valve, like a butterfly valve, you can actually see it move when you throttle up.
Old Mar 23, 2009 | 01:20 PM
tk353's Avatar
tk353
yes i saw that in my manual. it is an option. you wont use it any longer when you change pipes but i donot think it has any electronics that would cause an error code but i will look, it is called active exhaust and it has no electronics
Diggman
Sep 22, 2013 07:31 PM
Waylenlee
Jul 30, 2012 01:59 AM
bbqbrisket
Jan 1, 2010 02:08 PM
Zapper
Exhaust System Topics
Nov 12, 2008 02:57 PM
Coastie71
Sep 1, 2008 07:51 AM
