Installing Apes on 03' Heritage
Old Mar 25, 2009 | 07:45 PM
Missouri-Heritage-Guy's Avatar
Default Installing Apes on 03' Heritage
Got the bars mounted, the throttle and idle cables hooked up, the clutch cable hooked up at both ends....Now the issue.
I need to splice the wires on both sides..What is the best way to do it, just cut each side in the center of the harness from the tank area to the bars, or?..Also, would you solder them, or use connectors, and then shrink wrap?...Thanks
Old Mar 25, 2009 | 07:53 PM
wildman67's Avatar
wildman67
are you talking about the wires comming from the switch housings? you can buy exstensions from harley or aftermarket like j and p, and I belive you don't have to cut your wires.
Old Mar 25, 2009 | 08:00 PM
mojojones's Avatar
mojojones
I used Novella extensions and they worked great
Yes,
The wires coming up for the turn signals, horn, start switch, etc...It looks like under the tank that the wiring harness is solid and no connectors anwhere to add length to.
Old Mar 25, 2009 | 08:34 PM
HD F250's Avatar
HD F250
There is a Deutsch connector on each side. Trust us..
Old Mar 25, 2009 | 09:48 PM
elvis8310's Avatar
elvis8310
I know on the 09's there is a connector and J&P has the parts to make them longer.
Old Mar 25, 2009 | 10:02 PM
wildman67's Avatar
wildman67
Originally Posted by Missouri-Heritage-Guy
Yes,
yeah you take the connector off the end. (you can push them out with the end of a paper clip) and add the exstesions. they unplug under the tank you have to remove or lift your tank.
Old Mar 25, 2009 | 10:03 PM
BOOGIE's Avatar
BOOGIE
Never used the extensions....sounds easier than soldering and heat shrink....then pulling all of the wiring threw a set of 18" Z-Bars!!!
I would heat shrink regardless just in case of moisture.
Are you running the wiring "threw" the bars.... because sometimes the connectors are to large to run inside the bars.
Old Mar 25, 2009 | 10:05 PM
wildman67's Avatar
wildman67
=1 heat shrink the wire's, but you can still pull them threw the inside of the bars. just helped a budd pull his inside his lowrider bars!
Old Mar 25, 2009 | 11:24 PM
Thanks guys,
I wanted to hide them in the bars, and still will if the can get the wires to fit with the connectors..Cleans up the look..Got everything done now but the wires..I will lift the tank and see where the connectors are.
