Spitting, Sputtering, & Hiccups
Old Mar 28, 2009 | 09:00 PM
sixpack_sid's Avatar
sixpack_sid
Default Spitting, Sputtering, & Hiccups
I have an '89 Softail. I took it for a ride yesterday and it started to spit & sputter. I recall it doing that last year, too. It doesn't want to stay running, you have to give it a little more throttle to keep it running. Sometimes when I'm coasting, it "hiccups"-it cuts out and then picks up again. What's involved in a tune up? Can I put a carb cleaner additive in the gas tank? I bought one but don't know if I should use the whole bottle-it states for 21 gallon tank. I changed the carb last season from the stock carb to a CV from a '93.( I had the problem with the old carb also.)
Any help would be appreciated!
Thanks!
Old Mar 28, 2009 | 09:06 PM
anubisss's Avatar
anubisss
Drill out the mixture screw and give a few turns in either direction until it idles smoothly, assuming that the carb is the issue. Did it start when you put the carb on, or before? You could also clean out your tank and see if that helps. Or, tear down the carb and rebuild it.
Old Mar 28, 2009 | 09:50 PM
I8SMK4U's Avatar
I8SMK4U
Check your electrical too. Make sure your coil is getting 12 V and your battery is good. I have had symptoms like that and found my battery cell tops were not covered in fluid. Thing was only putting out 10 Volts.
pieisgood
EVO
22
Apr 17, 2015 10:03 PM
06hds
Oct 25, 2012 03:19 PM
ernofsteel007
May 24, 2009 05:42 PM
sixpack_sid
Exhaust System Topics
Feb 23, 2008 10:16 PM
Rat bike
Ironhead
Jul 8, 2007 04:21 PM
