FLST owners with engine guard - question
Old Apr 1, 2009 | 02:53 PM
SURFOR Chop's Avatar
SURFOR Chop
Default FLST owners with engine guard - question
I installed a FLST front end on my Super Glide about a year ago. Last fall I installed an engine guard.
Not long after that, I noticed there was a mysterious dent across the back of my fender between about the 10 O'Clock and 11 O'Clock position (when viewed from the right side).
I was recently told that it was on account of the front end bottoming out and coming into contact with the horizontal member of the engine guard.
I am trying to ascertain how common an occurrence this is and if there's anything that can be done about it -- other than watching the road conditions more carefully to avoid bottoming out the front end.
Any experience or tips are appreciated. Thanks!
R/
Priest
Old Apr 1, 2009 | 03:45 PM
ElSupremo's Avatar
ElSupremo
My bike is lowered and I don't think even at full compression that the fender would touch the crash bar.
Old Apr 1, 2009 | 03:57 PM
keno's Avatar
keno
Not even close to touching it on mine.
Old Apr 1, 2009 | 11:14 PM
oct1949's Avatar
oct1949
Is the rake of the frame different on the two bikes, if so that could be the problem.
Old Apr 1, 2009 | 11:40 PM
Truckbizz's Avatar
Truckbizz
Account Deactivated
Its not even close on mine either.
Old Apr 1, 2009 | 11:59 PM
I8SMK4U's Avatar
I8SMK4U
Mine was lower 2" in the front. New Tins and paint and within two days I bottomed out going into a parking lot. The front fender hit the cross bar on the two spot lights. I put new fork tubes in that were stock length and went to a 30W fork oil instead of 20W. If your forks are stock you may dampen better with a thicker weight fork tube oil.
Old Apr 2, 2009 | 12:18 AM
SURFOR Chop
I think there is a degree or two of difference at least (which would account for the fender being a little closer to the frame) ... could've contributed to my issue ....
I don't think there's an issue of hitting my 'hammock' bar for the passing lamps/turn signals ...
My engine guard is from the 'touring' models, and part of my 'work around' to make it fit is it mounts in front of the frame crossmember ... someone on the Touring forum suggested that may have been an issue. Combined with the difference in rake, that may explain it ....
I think I'll try a heavier grade of fork oil ...
Thanks for the insights!
R/
Priest
Grizzwood
Aug 11, 2014 08:10 AM
Jethroe
Jan 7, 2012 10:23 PM
harley_nova
Aug 26, 2009 06:07 PM
jd140400
Apr 6, 2008 07:16 PM
Driz
Oct 11, 2006 10:22 PM
