True Duals
Old Apr 8, 2009 | 07:46 AM
jmsoftail94's Avatar
jmsoftail94
Default True Duals
Has anyone put dual exhaust on a FXST/C? Just wondering if its possible and what issues it causes. Post some pics if you got em! Thanks
Old Apr 8, 2009 | 07:55 AM
I8SMK4U's Avatar
I8SMK4U
Same question here. All i can find from the companies are kits that start at 1995 and my FLSTC is a '94. The only thing I found is getting a header pipe from Paughco and putting on different mufflers.
Old Apr 8, 2009 | 09:59 AM
Mordrapheus's Avatar
Mordrapheus
If memory serves right you should be able to use the Screaming Eagle crossovers, which use the springer setup, at the very least. I do not see what the V&H true duals would not work, but not sure on that.
Old Apr 8, 2009 | 10:09 AM
Mordrapheus
Can't imagine why this should cause any problems other than possibly mounting issues. My advise is ask dealers and indies whether they have done this and how it would work.
Old Apr 8, 2009 | 12:58 PM
C Clamp's Avatar
C Clamp
Default True Duals
I was just up at the local Indy getting a tire on the wifes Heritage and one of the techs was putting Samson True duals on a guys Deluxe. I held the small pipe on the exhaust side while he slid the other in to it from the other side. Looking at it, was a pretty clean install. He was putting fishtails on it also.
http://www.samsonusa.com/products/sf.../318/sfID3/206
Don't know if this helps but my 2c.
Old Apr 8, 2009 | 09:21 PM
Greatful_Ed's Avatar
Greatful_Ed
I have V&H True Duals on my 2007 FXSTC. Love them.
Old Apr 8, 2009 | 10:39 PM
anubisss's Avatar
anubisss
True duals make the rules...
Old Apr 8, 2009 | 10:56 PM
jmsoftail94
I started looking around, and I have run into the same problem. They only make dual exhaust for 95-up. I have a 94 FXSTC. Am I SOL or has anyone found pipes for 94 and lower? Ed, those V&H look good!
Old Apr 9, 2009 | 03:19 AM
grbrown's Avatar
grbrown
I believe the top of the primary chaincase is a different shape on earlier bikes. I have Samson true duals on my 1990 dresser, but the clearance of the left pipe to the chaincase is minimal. I trimmed the heatshield to stop it vibrating against the casting.
So later pipes may fit if you are prepared to do battle with the pipe off the rear cylinder.
user 78082023840
Exhaust System Topics
Sep 6, 2018 05:08 PM
timber0472
May 11, 2014 05:18 PM
mazzurco
18
Jun 25, 2010 08:43 PM
Dax4800
Mar 12, 2010 01:42 PM
RKCustom
Mar 12, 2007 10:27 PM
