yep..their right. front are a dual element bulb from the factory. run/turn. the rear are a single element, and thats what the module affects. steve
Your right, I went back to the package when I replaced the Front Lenses because I changed the bulbs also and put the originals in the package and they were Dual Elements.
Thanks for all the help, I guess I never stand in front of the bike to often with the lights on to ever notice.
08 Street Glide, RTB installed, but brake not working
Installed an HD module with a Street Magic load equalizer and red LED's. Problem is, the rear turn signals will not come on as brake lights. The turn signal and running lights perform great. Any ideas?
The HD module will not work with LED's (found this out the hard way). You'll need a Kuryakyn or one of the other LED makers modules.
I used a Kury myself.
Thanks for the insight, I was afraid that was the case. Of course my local dtealer did not mention that, and electricals are not returnable. Another $50 lesson. Thanks again for the help!
Glad someone brought this up. I have a question....
My 02 Deuce has the HD kit. All running lights (tail light, L & R signal lights) work fine. My right signal light works great with the brake light BUT, when I turn on the R signal light .... all three flash. What did I screw up?
