is a Fatboy rim the only basic rear solid rim choice for my 03?
Old Apr 19, 2009 | 09:59 AM
xxxflhrci's Avatar
xxxflhrci
Originally Posted by tlb
you would need the 03-06 fatboy rear wheel, it is different than the 00-02 fatboy rear wheel. are you looking for a chrome, polished, or stock wheel?
The only difference is the bearing size. No big deal. They can easily be changed.
Old Apr 19, 2009 | 10:06 AM
schumacher's Avatar
schumacher
a 1200C rim will bolt right up, eh?
hmmmmmm
Old Apr 19, 2009 | 10:24 AM
tlb's Avatar
tlb
That is not true, the bearing size is the same. In 03 Fatboy went to a 150mm rear tire. Instead of changing everything, for clearance. MOCO changed the hub offset on the rear wheel. So the 03-06 Fatboy rear wheel fits without worries about clearances causing belt rubbing issues.
I checked all of this extensively when I was shopping for new wheels. Many wheels will just bolt in, kinda like many different shoes will fit, however, the proper size will not cause issues, later.
Old Apr 19, 2009 | 09:35 PM
xxxflhrci's Avatar
xxxflhrci
hmmmmmm
It should. Use the MoCo catalog to do the cross referencing.
TLB is also correct about the offset....I forgot about the wider tire/narrower belt on the newer Fat Boys.
WanaRyd Wheels
Vendor For Sale Classifieds
Dec 18, 2015 11:05 AM
jrider62
Jul 1, 2014 11:44 AM
magnum629c
Dec 8, 2012 10:38 PM
wideglidebob
Jan 24, 2010 08:04 AM
anubisss
Nov 17, 2008 06:59 PM
