20K service question
torx? will I absolutly need a motorcycle jack/stand for this? anything else you can think of.
Thank you very much in advance for any tips
Good luck.
Always torque all nuts and screws to specs. Always torque all nuts and screws to specs.
Belt tension tool from HD for checking drive belt.
Some t-handle allens and a recessed 11/16 box wrench are good for adjusting the clutch but not necessary.
I'd had a jack (J&S) from day 1 so I can't imagine not having one. Suppose in a pinch you could get by.
Hand impact tool is good to have for stuck bolts. I've read of alot of horror stories about frozen bolts and screws that get broke off so whenever I have a questionable bolt or screw I give it a couple shots with the impact tool. So far so good. It's important to always use the correct size allens and torx and always seat them all the way. Even if you have to tap them a bit.
Just did my 10k. Time consuming but all in all it went well and I saved myself about 5 bills.
_______________________
2008 Heritage Classic: His
2008 Deluxe: Hers
2008 Deluxe: Hers
Awesome that was exactly what I was looking for thank you very much.
