Stage 1 BS
Old May 13, 2009 | 06:36 AM
HDChloe's Avatar
HDChloe
Originally Posted by jimmers1817
Don't ya mean, RICHER?
______________________________
2008 Heritage Classic: His
2008 Deluxe: Hers
I assumed that is what he meant as well. lol
Old May 13, 2009 | 07:56 AM
'05Train's Avatar
'05Train
Originally Posted by chop09
Can some one tell me what a TTS is? Who builds the map on this system if not the dealer?
http://www.mastertune.net/dealers.html
I got mine from JD's CycleWorks in PA. Basically, it's an upgraded SERT, made by the company that used to make the SERT for HD. The link up there will explain what the TTS does. If you're not planning on having the bike tuned immediately, call Doc at 352-242-9616, and he can get your base map squared away for you.
Old May 13, 2009 | 08:23 AM
Damage_Inc's Avatar
Damage_Inc
FWIW I have Pipes, A/C, Xied's and the stage 1 download,the bike runs fine but the fuel mileage is not so good.
IMHO if your just doing pipes and a/c on the newer efi bikes,the XIED's are sufficient but they're by no means the best way to do it. I bought mine from an indy shop that sells about 10-15 units a month to guys looking to do what you want to do. He asked me a few questions about what I wanted to do with my bike and then he suggested the Xied's. I asked them "what if it doesn't work?? He said "yours would be the first one I've seen that didn't". He also said if I wasn't happy he'd give me my money back, I figured WTH,they were worth a shot and like I said the bike runs fine. This same indy sells them all from Xied's and PCIII's all the way to the Thundermax and I feel this guy was on the level. He said eventually I'd be back for a Thundermaxx with a wink but the XIED's would work perfectly in the meantime. So far so good, only compaint would be fuel mileage.
Old May 13, 2009 | 09:01 AM
refuzeandrezizt's Avatar
refuzeandrezizt
2008 Deluxe: Hers
Yeah, sorry, too much to drink last night I guess . Good catch though!!
Old May 13, 2009 | 11:55 AM
HDChloe's Avatar
HDChloe
So with the xied....how bad is the gas milage?
I spoke with Fuelmoto and they recommend the PC5, even though the power Commander website says it won't fit a Cross Bones. I would have to take the relay bracket apart. The Fuel Pak won't directly fit without cutting the battery cover. So basically nothing is truly plug and play except the xied which seem to be not well received on this forum for the most part.
Heck, maybe I will just start trailering my bike so I don't have to start it. Lol
Old May 13, 2009 | 12:03 PM
HDChloe's Avatar
HDChloe
I guess ultimately I am just annoyed. Simple doesn't seem to be an option here.
Old May 13, 2009 | 12:06 PM
'05Train's Avatar
'05Train
No fitment issues with a TTS.......
Old May 13, 2009 | 12:39 PM
trapper_canada's Avatar
trapper_canada
From everything I have read I don't think people are disappointed with the Xied for what its purpose is. To run the mixture more rich to ease off on the heating and to improve some of the throttle response. I think most people get that...but then they get the hunger for more performance which the Xied is really not intended for.
I have had the Xied for a little bit...noticed an improvement in heat and in some throttle response. I am pondering a fuiel management device...but not cause I am unimpressed with the Xied (I think they are great bang for buck) but because I may want to do more.
Old May 13, 2009 | 01:21 PM
Damage_Inc's Avatar
Damage_Inc
^^ Well said... If you are content with just pipes and a/c the Xied's will work fine. I thought $100 is better than $500 right now as I won't be doing any more engine mods this year. If and when I decide that more power is needed, I will be switching to the Thundermaxx or something similar.
Gas mileage is noticeably worse! I can't give you numbers as I don't watch it that closely, if it needs gas I put more in. Educated guess would be be about 50-75km less per tank. It seems like I'm at the pump a lot sooner now than before.
Old May 13, 2009 | 03:12 PM
jimmers1817's Avatar
jimmers1817
No new A/C = No need for fuel manager= SIMPLE
I've been simple for almost 2 years now and have no complaints. Rush 1.75s and 42-50mpg is just fine and dandy for me.
2008 Deluxe: Hers
