rear tail light question
Old May 14, 2009 | 09:20 PM
klf33's Avatar
klf33
Default rear tail light question
Hi Guys,
My rear light bulb blew up, I took it out, I have a question
I found this greasy clear color material on the bottom of the bulb (right at the contact points in the bottom), is that normal ? what is that really ?
I am curious, I hope it is not a big deal , the bulb was also blown as in BLOWN !, like exploded and it made me really worry .. I hope I don't have a short or anything like that.
I appreciate your help
Regards
Old May 14, 2009 | 09:27 PM
rel3rd's Avatar
rel3rd
That was more than likely di-electric grease, which is a good thing and nothing to worry about.
Old May 14, 2009 | 09:30 PM
snip0721's Avatar
snip0721
it's called die electric grease. it's to help avoid corrosion.
Old May 14, 2009 | 09:31 PM
crazybastid83's Avatar
crazybastid83
It is dielectric greASE. It prevents corrosion, it is suppossed to be used there. Replace your bulb and use the grease.
klf33's Avatar
klf33
Thanks Guys,
Any idea if it is normal for the bulb to be broken when I looked at it (it had a hole and looked totally burned .
Old May 14, 2009 | 11:04 PM
crazybastid83
it happens
Old May 15, 2009 | 12:19 AM
klf33's Avatar
klf33
Thanks Guys,
Old May 15, 2009 | 08:11 AM
tk353's Avatar
tk353
di-electric grease. for the bulb to be like that it most likly was water or moisture or temperature change.
Old May 15, 2009 | 08:45 PM
oct1949's Avatar
oct1949
Haven't change many bulbs in your life... they been using that for years!!!!! and good ole yellow or white grease before that....
jmsoftail94
Aug 8, 2017 02:55 PM
RLJO
May 7, 2010 07:36 AM
stevieg
Jan 2, 2008 01:32 PM
stevieg
Dec 29, 2007 02:21 PM
MidWest XL
Feb 2, 2005 10:40 PM
