09 Fatboy owners - Stage 1
Old May 15, 2009 | 09:58 AM
FrankT's Avatar
FrankT
Default 09 Fatboy owners - Stage 1
Hey guys,
I'm reaching out to all '09 Fatboy owners to get a consensus as to how you upgraded to stage 1, particulary which fuel mgmt system did you use? This is by no means any disrespect to all other HD owners, but I wanted to get the info from those with the same model/year bike as me. I was all set on going with the PCV, however when I took off my seat on my '09 Fatboy for the first time, it seems like it is going to be a royal pain in the a$$ to get the unit to fit. I was then looking into the TMAX (very costly as well as not too comfortable replacing the stock ECM) or the new Screamin Eagle Super race tuner or perhaps just a dealer download. I am planning on going with the V&H BSS pipes and SE air cleaner. I don't plan on doing any mods after that. I just want the bike to sound better, perform better and run cooler. This is very confusing and I am starting to get frustrated. I am spending more time on this rather than riding!.....what is wrong with that! Any info would be appreciated. Thanks.
Frank
Old May 15, 2009 | 10:17 AM
ngoti8tor's Avatar
ngoti8tor
I have an 08 which is the same as the 09. I used a Fuelpak with my V&H pipe and the SE air cleaner. I'm happy with the way mine runs.
Old May 15, 2009 | 11:51 AM
gunner065's Avatar
gunner065
I too have an '08. I have the V&H BSS with the SE AC but a K&N filter. I have the download and no regrets.
Old May 15, 2009 | 12:04 PM
FATBOY777's Avatar
FATBOY777
my bike is going to the dealer tomorrow to get V&H BSL, se air cleaner and the download tune from harley. i have a budget of 1k and all of this including instalation will run 1k. The dealer said this is the way to go so lets see how it turns out.
Old May 15, 2009 | 12:12 PM
FrankT's Avatar
FrankT
Gunner065, you have the exact setup I'm looking for (even the same color!). Do you have any issues with popping on decel? Also, do you have the standard baffles in your BSS or the quiet ones?
Old May 15, 2009 | 02:02 PM
jed1069's Avatar
jed1069
I have an 09 Fatboy with BSS and Arlen Ness Big Sucker I bought a PC-V from fuelmoto.com. Call them tell them what mods you have it will come with a Map loaded in it. It took me roughly an hour to install it after I got it. Just be patient it will fit you just will have to do some trial and error. I fired the bike up it runs great. I had run it about a 100 miles with no PC-V the engine ticked like crazy when I would shut the bike off. Now no ticking at all I am assuming because the engine is running cooler. Hope this helps.
Old May 15, 2009 | 07:53 PM
gunner065's Avatar
gunner065
I don't have any issues with decel popping what so ever. I have the standard baffles and love the sound. Originally I had the SE air cleaner, but it started to break down after only 900kms. The rubber started to break down and was being sucked into the motor. Went back to the dealer and they gave me a K&N (which they used previously) and not had a problem since. I would upgrade to the K&N from get go to avoid this problem. By doing a search here you will see that this is a common problem with the SE AC.
Old May 15, 2009 | 07:56 PM
FATBOY777's Avatar
FATBOY777
good info on that se air cleaner gunner. ill have to askthe dealer about that tomorrow
Old May 16, 2009 | 03:19 AM
tk353's Avatar
tk353
gee i got the thundermax used in the forum for about $450 and that was about less than the PVIII and the dyno tune. replacing the stock ecm is no big deal. when you change your pipes you install the new 02 sensors. I had a PCIII before this last mod and i just could not see spending another $420 for a dyno tune.
Old May 16, 2009 | 07:57 AM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
ThunderMax on my '08, as well. No regrets. She runs strong. It wasn't as hard to install as I thought it would be. Using the software, however was a different story. Not quite as intuitive as I would have liked, but there is a lot of help available on this forum and from Zippers' support team.
