Ness Drop Kit BLOWS!!!!
Old May 24, 2009 | 09:33 AM
  #31
John TN's Avatar
John TN
For sure keep coming back, your trail is easy to follow. BTW, that was a cool video!!
Old May 24, 2009 | 09:36 AM
  #32
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Idiot Trolls. If you want to act like a child then we will treat you like one.
Old May 24, 2009 | 10:14 AM
  #33
Hammer107's Avatar
Hammer107
This one is funnier.
[youtube]<object width="340" height="285"><param name="movie" value="http://www.youtube.com/v/Nd68WjDIBqk&hl=en&fs=1&rel=0&border=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Nd68WjDIBqk&hl=en&fs=1&rel=0&border=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="340" height="285"></embed></object>[/youtube]
Old May 24, 2009 | 11:19 AM
  #34
John TN's Avatar
John TN
So now we have him on his Harley and crotch rocket!!
Old May 24, 2009 | 01:20 PM
  #35
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
And my Arlen Ness drop dampners still BLOW!
Old May 24, 2009 | 06:09 PM
  #36
John TN's Avatar
John TN
You didn't put the progressives in last night??
I'm looking into doing something to my RK it's been lowered so I have that strike, but it's not a terrible bad ride, except on a pot hole or hard bump at speed on the freeway, but any improvement would help, time to change the fork oil which might help some, so I thought since I had to take so much apart I might look into doing some springs or something.
Old May 24, 2009 | 06:21 PM
  #37
John TN's Avatar
John TN
Originally Posted by DaddyKnuck
Short lengths of PVC are old school tech to increase spring preload. Low tech, but works and is very cheap. Get a couple of feet of PVC pipe and cut 2 pieces at 1/2", 2 @ 3/4" and so forth. You can play with the amount of preload until the ride is right. What I don't understand is their advice to use heavier oil. A heavier weight fork oil will slow down the first compression (bump), but it will also slow down the recovery (rebound). On a rough road the rebound gets behind the compression far enough and pretty soon you are locked down at the bottom. What increasing the preload will do is reduce your static sag (free compression of the springs that happen when the bike isn't moving). I'm not sure how increasing preload will fix a damping problem.
Unfortunately stock Harley's are equipped with only marginal suspension. Lowering one of them by reducing suspension travel is not normally going to improve the ride. Good luck.
That sounds like what's going on with 09's bike, or possibly the amount of oil is incorrect (too little or too much) the heavy SE fluid is too thick or some valves or dampers are trashed up. Temperature can also affect the fluid flow through the valving and dampers as well, also one must make sure there is no binding to the fork sliders and the fork tubes are true in the runout amount (straightness), and as said the suspension is marginal at best, now y'all have me thinking about my forks!!!
Old May 24, 2009 | 06:43 PM
  #38
ElSupremo's Avatar
ElSupremo
When are you getting the Progressives put in, or have they arrived yet?
Old May 24, 2009 | 08:33 PM
  #39
Skies of Texas's Avatar
Skies of Texas
Childish is talking smack about "plastic" Japanese bikes and then putting polyvinylchloride shims in your steering system.
Hi guys!
I have acouple of other registered names I'm going to use, too. They're just not quite so obvious as this one.
Man, you guys are TOO easy to get a rise out of. Insecure much? lol.
(you should know that these days there's no way to ban someone from a forum. Proxys beat vBulletin all day long. I'm not going anywhere)
Old May 24, 2009 | 08:57 PM
  #40
Skies of Texas
Oh, and while I really dig the vid of the squid on the SV650 plowing the tree - you should really think about it a little deeper:
Rider with no helmet who obviously doesn't know how to ride running off of the road into a tree. Sounds a lot more like your typical Harley rider than your usual sport biker.
Anyway, here's the video I had originally posted. It's Lee Shierts running a 7 second pass on a GSX-R1000. Your real moto-aficionados will appreciate it.
http://www.youtube.com/watch?v=bXWkdppa7dU
gl
