98 Softail Backfiring
Old May 27, 2009 | 07:51 PM
BikerBabeK's Avatar
BikerBabeK
Stage III
Default 98 Softail Backfiring
Can anyone help pinpoint what's going on with my 98 Softail. I took it out of winter storage, and I'm having issues with backfiring when I accellerate in 2nd and 3rd gears. I just replaced the spark plug wires and it's a little better, but the problem is still there. Is there a trick to making sure the wires on on correctly? Any other ideas?
Old May 27, 2009 | 08:19 PM
crazybastid83's Avatar
crazybastid83
You probably have to open up the carb, clean it out and replace parts etc. Check the float level, clean it out and buy a "James Gaskets" carb rebuild kit.
Sometimes opening the bowl and cleaning everything out does the trick, it all depends upon what you find when you open it up. It is really easy to do. If you don't have the tools to clean the jets, replace them, they are cheap.
Old May 27, 2009 | 08:20 PM
crazybastid83
Using dielectric greas on the plug tip where the wires go on is a good practice, but probably won't help in your case.
Old May 27, 2009 | 10:11 PM
murd's Avatar
murd
Is it possible you are burning bad gas left over from storage?
..just a thought...
Old May 28, 2009 | 06:16 AM
trigg's Avatar
trigg
2nd Gear
Default 98 softail backfiring
I had the same problem the gas was old drained it out. Put in high test in it and now it runs good
Old May 28, 2009 | 08:51 AM
BikerBabeK's Avatar
BikerBabeK
Stage III
Default Thanks for Ideas
I'll try putting in new gas. I was burning the reserves from winter storage (though I did add fuel stabalizer prior to storing). If that doesn't help, I may have to get into the Carb and pipes. That will be a learning experience for me Thanks for the replies.
Old May 30, 2009 | 09:58 PM
BikerBabeK's Avatar
BikerBabeK
Stage III
Default Success
New tank of premium solved the problem. I also got advice on how to better winterize her. Next spring shouldn't be as rough. Thanks for all the suggestions and help. Happy Trails!
Old May 30, 2009 | 10:08 PM
nova_SS's Avatar
nova_SS
Since you have a petcock you can disconnect the hose and drain the tank. Fill it with fresh gas and go to any auto parts store and buy a can of seafoam. Follow the directions and add it to the gas. Stuff works great. It's definately worth a try before tearing things apart.
Lukeb91787
Aug 2, 2017 04:25 PM
Codyyy
EVO
Aug 15, 2016 01:51 PM
mongoHD6684
Aug 13, 2013 07:43 PM
gallen1
Jul 8, 2013 07:09 AM
Keith_71
Jul 30, 2011 05:35 PM
