Rocker Customization Question
Old May 31, 2009 | 12:48 PM
DevilDogg's Avatar
DevilDogg
Originally Posted by jaysonL
Sure do. Look at a deuce with the heart land kit, and compare it to the rocker with the heart land kit. Same tank, front end, similar bars. The only real difference between the two is the speedo placement. Look at the thread below, and tell me you don't see a strong similarity between the Deuce, and the Rocker.
https://www.hdforums.com/forum/softa...completed.html
True, I guess the only other difference I can think of is the rake and the rear tire size.
Old May 31, 2009 | 04:07 PM
Joe What's Avatar
Joe What
The tank on a duece is the exact same one on a Rocker.. I increased my rake by 5 degree with an inverted front end... 300 huh.. hmmm big ole tire...
Old May 31, 2009 | 04:46 PM
Rocker-Mike's Avatar
Rocker-Mike
Your bike looks awesome. What all do you have to do to increase the rake on the front end? Is it a whole new front end? How much does it cost?
Old May 31, 2009 | 04:48 PM
Rocker-Mike
I think Harley all ready made a Rocker with the fender hard mounted with struts. They called it the Deuce.
When I bought my Rocker last year, the person I was dealing with at the dealer told me the Rocker was kind of like a Deuce on steroids.
Old May 31, 2009 | 05:40 PM
m i k e's Avatar
m i k e
Originally Posted by D.Wiggs
My rake was increased 4° with the inverted front end and I have a 260 on the rear. You can do a 300 but it envolves MAJOR welding and fab work; more than I thought it was worth. Figure on $11,000 MINIMUM for a 300 rear tired once you factor in the fab work, the wheel/tire combo, and the kit and transmission itself. For $4,000, you can run a 260. It was a simple cost/benefit analysis for me.
$11,000? is that all
chump change
gimmie 3 of those to go.
$4,000 for just a tad bigger? wow im in the wrong buisness for sure
man that sounds pricey i'll keep my 240 my $4,000
and still have a faster bike ha ha
btw 300 tire runs like dog,the 240 on the rock handles beautiful
good luck
Old May 31, 2009 | 05:42 PM
m i k e's Avatar
m i k e
Originally Posted by DevilDogg
Yeah, I guess if I can get away with that come out much cheaper. Guess the extra 40 isnt worth another 2k plus the price of wheels. But you have to admit, a 300 would look badass on the rocker haha.
I've had mine lowered for over a year now, rides rough as hell but I felt very uncomfortable with how the seat sat up in stock setting. Also, I have contacked jackyl about getting the 2in lift for the tank. I think the lines look much better with it.
Hurry up and get your pics posted man.
+1 on the lift
Old May 31, 2009 | 05:44 PM
DevilDogg's Avatar
DevilDogg
I'm planning to go with a 18degree rake with +10in tubes. I was wanting to go with inverted since they look cool and I heard they actually ride better but its 900 more dollars so I think I'll hold off on that one.
Old May 31, 2009 | 09:23 PM
Rail's Avatar
Rail
You gonna do it the right way and rake the neck or do it with the trees? I think at 18* and +10 your trail is really going to suffer unless you do some serious frame mods.. IMO, the Rocker was meant to be a pro-street style bike not a true chopper although I can't wait to see it when you're done.. Should be interesting..
Old May 31, 2009 | 09:26 PM
DevilDogg's Avatar
DevilDogg
AME makes a kit that gives the same effect of doing it with the neck w/o having to actually cut it. AKA: doesn't screw up your trail.
Old May 31, 2009 | 10:05 PM
DevilDogg's Avatar
DevilDogg
Touching on the inverted forks again. A friend told me his bike rides a lot smoother with them...I wouldnt naturally assume they would make a big difference. Anyone know if this is true or not?
