Level of difficulty on the fun meter??
Old Jun 11, 2009 | 07:13 AM
scooter34's Avatar
scooter34
Default Level of difficulty on the fun meter??
I wanna pull my oil tank on my X-Bones a get it painted, my question is what is the fun level on accomplishing this task and do I really need that tool to remove the oil lines?? Thank you
Old Jun 11, 2009 | 08:13 AM
J's Avatar
J
I just did mine on my Fatboy to get it powdercoated. It was much easier than I thought and no you don't need any special tools. Just get new adjustable hose clamps to replace the stock crimp-on type. Good luck
Old Jun 11, 2009 | 07:31 PM
CANTDR55's Avatar
CANTDR55
One tip on putting lines back into the tank (side by side near filler neck) Inside tanks holes there are two small O rings for eachg line. You might want to get a replacement kit that comes with new O rings and clips. about $8.00 bucks a pair from HD. Reason I say to replace is when I change my oil I use the scavanger system where you pull the filter and put a by-pass on it, pull the return line oil line out of the tank and attach a hose, refill tank and start the bike and let the dirty oil from motor get flushed into a can and then you re-attach hose.
I've done that on two oil changes without any problems. Third time I did the change, rode about 40 miles no problem, then next day on a ride oil leaked from the return line all over bike after about 30 miles. Lucky I was near an HD dealer open on a sunday and picked up the new O ring kit and changed it in the parking lot.
HDF Tech
Oil Archive (no new posts)
29
Feb 24, 2022 09:43 PM
Keith_71
Jun 26, 2012 04:16 PM
Bonaro
Sep 6, 2011 01:54 PM
95yj
Apr 2, 2009 12:23 PM
ROADRAGE98
Apr 13, 2006 11:46 PM
