Slammin A Fatty
Old Apr 22, 2005 | 02:48 AM
ColoradoGlide's Avatar
ColoradoGlide
Default Slammin A Fatty
If i lower rear about 1 1/2" how much tension will this put on
the belt, or should i just go ahead and ajust it?[8D]
Old Apr 24, 2005 | 06:36 PM
JeffD's Avatar
JeffD
Default RE: Slammin A Fatty
Should not be a problem. I lowered my Softail, and the tension on the belt is the same.
Old May 3, 2005 | 05:10 AM
T wrecks's Avatar
T wrecks
I lowered my 94 FXSTC one inch ten years ago, no troubles since.
Ride safe
Old May 4, 2005 | 10:56 PM
Dana's Avatar
Dana
6th Gear
i slammed my fatty all the way down to the stops, about 2.25 inches, 50000 miles and i never have had to adjust the belt
Old May 6, 2005 | 11:44 PM
Dana's Avatar
Dana
6th Gear
i sent you an email but i dont think you got it in regards to how fat of a rear tire can you go. i put a metzler 150 on my bike, i bought the pully axle spacer out of the widr tire kit, only a couple of dollers, then the differance in length between that one and mine i ground off the out side axle area of my brake caliper. this moved my rim over and centered it in my fender, i had already modify my inner fender splash sheild. i had cut the sides off. also i had already put new struts on my fender that have no visable bolts. the important thing is that there are no bolts stickin through the fendrer into the tire, you could get button head bolts in from the inside of the fender with acorn nuts on the outside, yes they are modifications but very minnor and could be done on the afternoon, if you have any ? or problems or need any part numbers let me know.
WFO FXSTB
Jun 16, 2013 05:45 PM
883drummer
Apr 22, 2013 05:58 AM
Remnighttrain
Sep 29, 2009 06:25 AM
Fatbob Slim
Mar 14, 2009 05:48 PM
OKIEVO
Dec 21, 2007 12:10 PM
