rear brake pad replacement
Old Jun 19, 2009 | 06:37 PM
oliver99's Avatar
oliver99
Default rear brake pad replacement
i have to change the rear pads on my friends 03 fat boy. any help or tips on doimg this. do i need to take the whole caliper off and then bleed the brakes or can i just undo the 2 screws in the middle and slide the pads out and then just push the piston back.
any help or ideas would be great. thanks
Old Jun 19, 2009 | 08:47 PM
jcoers's Avatar
jcoers
I would think it is similar to my 07 Deluxe. You pry the pads away from the rotor then back out the retaining pins until the pads can slide down. You don't need to remove the caliper, but you do need to take the cap off the fluid cup so it will allow the pistons to retract all the way.
Did any of that make sense?
Old Jun 19, 2009 | 09:17 PM
'05Train's Avatar
'05Train
I just changed the pads on my 'Train. You don't have to mess with the fluid at all. Loosen (or remove) the pad retaining pins. Use a wood paint stirrer to force the pads away from the rotor. Pull the old pads out. Use the paint stirrer to force the pistons all the way in. Slide the new pads in. Re-install the pins.
Old Jun 19, 2009 | 09:30 PM
oliver99's Avatar
oliver99
done piece of cake. thanks
Old Jun 20, 2009 | 06:48 AM
tk353's Avatar
tk353
I would suggest you change the fluid but you dont have to remove the caliper
dont forget to clean the pistons too,
http://www.lyndallracingbrakes.com/service_tech.htm
Old May 14, 2010 | 06:41 PM
kiwideuce's Avatar
kiwideuce
off to the garage for me then
Old May 16, 2010 | 01:39 AM
kiwideuce's Avatar
kiwideuce
did it today,just need a 1/4" 12 point socket, remove master cylinder cover,everything stays on the bike,no need to even bleed brakes after!
that was my first time,pretty easy
Old May 16, 2010 | 01:43 AM
Deuceandahalf's Avatar
Deuceandahalf
Yes, piece of cake but its always a good idea to clean the pistons and change the fluid.
Old May 16, 2010 | 08:05 AM
bear68's Avatar
bear68
Deuce is givin good advice. If you have some miles, or time on the fluid. Brake fluid, even silicon DOT 5, is hydroscopic and absorbs water over time. This prevents water from building up in the system which can lead to freezing or rust, but over time it reaches the point of saturation. Replacing it with new fluid every so often prevents that. Doing the fluid change at the same time as you have all the tools out to do the pads just makes it more convenient and is a good reminded, kind of like rotating you car tires at each oil change. You don't have to keep track of two separate services, just do it all as a package.
Pete3323
Oct 2, 2017 03:10 PM
cubalz
Apr 4, 2014 08:21 PM
mteed23
Mar 16, 2012 05:49 PM
paguy
Jul 8, 2009 02:44 PM
jokr
Feb 3, 2008 06:10 PM
