Progressive Lowering ?
Old Jun 19, 2009 | 10:09 PM
NightTrainRob's Avatar
NightTrainRob
Default Progressive Lowering ?
I just got my lowering kit in the mail, and all that was in there was the 2 longs springs, the washers, 2 short springs, and the pcv pipes,
Isn't there suppose to be a total of 4 short springs? Just wanted to make sure before I called and complained about this, cause I really can't find anything about it but the instructions say something about using 2 in one fork
Old Jun 19, 2009 | 10:19 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Dammit Rob I tossed my notes on what we did on mine but we followed the instructions for the 2" drop and ended up with 2 small springs at the bottom of the stack, 2 more springs on top of that and then the long springs and the section of PVC pipe.
So each fork legs actually has 4 springs and the PVC pipe to get the 2" drop as the instructions describe.
Now I cant remember what was in the box....
Or what came outta the fork stock?
If you dont figger it out PM me and I'll go find the original box and see whats in it!
Old Jun 19, 2009 | 11:33 PM
NightTrainRob
Well, I've been looking online and can't find anything about it, according to the instruction sheet it should have had 4 small springs, and 2 long ones, but it only has 2 short ones...
Old Jun 20, 2009 | 12:17 AM
KumaRide's Avatar
KumaRide
It sounds like you could have the newer "drop in" setup. The "drop in" kit only has two short and two long springs and PVC. You cut the PVC to a length which determines how much your forks get lowered. Was just looking at that stuff today and spoke with Progressive about it. Go to ProgressiveSuspension.com and check your part number to see if it is the drop in kit. Otherwise, your kit is definitely incomplete.
Old Jun 20, 2009 | 02:54 AM
ElSupremo's Avatar
ElSupremo
Yep, that sounds exactly like the drop-in kit.
Old Jun 20, 2009 | 05:42 AM
Blk and Chrome's Avatar
Blk and Chrome
My drop in kit was like that. The box says drop in too.
Old Jun 20, 2009 | 09:45 AM
Carmell RKC's Avatar
Carmell RKC
Same here, drop-in.
Old Jun 20, 2009 | 11:13 AM
NightTrainRob
Its part # PS01561
forklowring spring kit
all it says
Old Jun 20, 2009 | 11:41 AM
DECON BLUE's Avatar
DECON BLUE
Thumbs up
Yep, if it is the drop in kit it has 2 long springs, 2 short springs, 4 flat washers, and pvc tubing. I cut my pvc to the shortest allowed and got just over 2" drop. 1 of the best mods yet IMHO.
Old Jun 20, 2009 | 01:48 PM
KumaRide's Avatar
KumaRide
Originally Posted by NightTrainRob
Its part # PS01561
all it says
That part # is for the standard kit - not drop in.
Fork Spring 11-1131
Lowering Kit 10-1561
Lowering Kit - "Drop-In" 10-2003
http://www.progressivesuspension.com...37&modelID=367
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
