Lowering bolt install issue
Old Jun 20, 2009 | 09:38 AM
2001 Softail Deuce's Avatar
2001 Softail Deuce
Default Lowering bolt install issue
Well I ripped my air shocks and compressor, that were on the bike when I bought it, out yesterday and put the stock shocks back on. Disappointment but glad to get rid of the pain in the a$$ things. We but the lowering bolts on the stock shocks but after hours of trying in a 95* garage we just couldn't get the shock to go in and the longer bolt to fit to the hole. We came to the conclusion that you must need a tool to compress the shock, slide it in place, bolt everything on, and take the tool off of the shock. Does this sound correct and how would get such a tool?
Old Jun 20, 2009 | 09:52 AM
Carmell RKC's Avatar
Carmell RKC
Mine slid right in. Try removing the grommets that the stud sits in on the frame cross member. You will have to slide the back one on the stud first.
Also, jack up the back wheel as far as it will go, that should give you all the room you need.
Old Jun 20, 2009 | 08:35 PM
story808's Avatar
story808
First off you can send the air shocks and the comp. to me... lol
Should be just like any stock shocks... You adjust the ht after it on the ground... So when you install them the adjustment nut is all the way back with the washer and bushing, stick the stud through the cross plate then bolt up the back.
Way don't you like the air shocks?
Old Jun 21, 2009 | 11:38 AM
2001 Softail Deuce
Carmell RKC, that's exactly the way I tried to install them. I tried everything possible but no way they're going in without compressing them to make them smaller. I guess that's not the correct way to install stock shocks with the correct lowering bolts. I'm contacting the distributer tomorrow to be sure I've got the right bolts for my bike.
Story808, I'll be more then happy to sell them to you. the compressor is great, there is a slow leak someplace that I could never find. thanks
Old Jun 21, 2009 | 02:38 PM
Hammer107's Avatar
Hammer107
I don't know how you are supporting the bike but if the rear wheel is in the air then there is a lot of play in the rear shock mount and you may need to move this up and down to install. I personally had the rear wheel off my bike the last time I did it so it was a snap to move the rear mount.
Screw the nut all the way towards the shock, put through the front hole all the way and you should be able to get the rear bolt started. Sounds like you have the bike on a jack with the rear wheel drooping which brings the rear mount forward quite a bit if I recall correctly. Try putting a small floor jack under the rear tire and jacking it up slightly.
Eazy Peazy.
Old Jun 21, 2009 | 07:33 PM
2001 Softail Deuce
I moved the rear tire up and down with a 2 ton jack. it worked great but never got the room. thanks
Old Jun 21, 2009 | 11:42 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
When i changed out my bolts on stock shocks they were a snap to get out. But let me tell you getting that damm shock back in was a pain in the A$$. I would say this mod was a headache. Just keep messing with it. It's a tight fit but they do slide in. Make sure that wheel is off the ground. The left side went into place with no problems but that right side was BS!!!
Old Jun 22, 2009 | 01:12 PM
2001 Softail Deuce
I'll keep working on it, I don't give up. thanks Dudes
Old Jun 22, 2009 | 02:42 PM
elvis8310's Avatar
elvis8310
Anyone got pics of how to install the lowering bolts themselves.
Old Jun 23, 2009 | 06:00 PM
WFA's Avatar
WFA
Hey duece...the hammer "nailed it". That's the way i did mine and that's the way hd techs do it. Follow his note and get-er-done!!
sbeamer
Jan 20, 2015 07:49 PM
Crazy
Feb 6, 2014 02:52 PM
Rolo101
Mar 31, 2010 01:39 AM
neocontra
Jan 3, 2010 06:55 PM
ski917
Jul 24, 2009 11:48 AM
