stock suspension
Old Feb 6, 2014 | 11:53 AM
Crazy's Avatar
Crazy
Default stock suspension
Hi guys: A buddy of mine just bought a 2007 Softail Standard that the previous owner had lowered with the longer bolts on the stock shocks. He would like to raise it back up to stock height, but the previous owner didn't have the stock take off bolts. Does anyone here happen to have some laying around that they'd like to get rid of?
Thanks
Old Feb 6, 2014 | 12:22 PM
Dead Creek Cycles's Avatar
Dead Creek Cycles
Former Sponsor
In most cases, the lowering bolts that are installed on the stock shocks are threaded the entire length and allow a range of adjustment both higher and lower (somewhere in the range of 2"). If this is the case with the bolts on his bike, he can easily raise it back up by loosening the flange nut in the front of the shock crossmember on both shocks, then loosening the hex nut behind the shock crossmember, and adjust them where he wants them and then tighten everything back up. It is a pretty easy adjustment. Just remember to adjust both shocks to the same length.
The adjustable type lowering bolts that I'm talking about should look similar to the picture below. If they are not fully threaded along the (thinner) shaft then they are not fully adjustable.
Old Feb 6, 2014 | 02:35 PM
Crazy's Avatar
Crazy
Thanks, I'll let him know to check that out.
Old Feb 6, 2014 | 02:52 PM
olongapo1's Avatar
olongapo1
Dead Creek has a good write-up. The only thing I can add is if the bolts are not fully threaded, your local machine shop can cut additional threads onto the shaft. I doesn't take much. An additional inch of threads would be all that is needed.
Ventana
Apr 28, 2016 07:12 AM
ZGram924
Nov 21, 2012 06:50 PM
2001 Softail Deuce
Jun 23, 2009 06:00 PM
hellfish
Apr 3, 2009 05:35 PM
serge627
Feb 4, 2009 12:17 PM
