XB jockey shift conversion
Old Jun 24, 2009 | 04:56 PM
Burzum's Avatar
Burzum
6th Gear
Default XB jockey shift conversion
hey guys, ive tried the search function and read through a bunch of posts but havent found the info i needed on converting my XB to jockey shift,
i looked at the labroila kit but it says 5 speed? why would that matter when your controlling the trans with a lever?
what do i need exactly to make the conversion, any troubles during installation? what parts need to be changed?
and especially where can i get these parts
thanks in advance
Old Jun 24, 2009 | 05:30 PM
Xuallus's Avatar
Xuallus
Cheesecake and Ole Coyote have done it, might want to check out their posts
Old Jun 24, 2009 | 06:07 PM
HaloFan's Avatar
HaloFan
Exile Cycles also has a Jockey Shift kit and foot clutch. Not sure if it's been priced yet. And they have a centrifugal clutch kit to make life much easier at stops and starts. Pretty trick....expensive...but trick. Paul in sales there is quick to respond and helpful and honest with his answers. I was buying other goodies but noticed these on their website and pdf catalog.
Old Jun 24, 2009 | 06:36 PM
Cheesecake's Avatar
Cheesecake
Talk to Rick at LaBriola... he'll set you up...
If your looking for a Jockey... you will get a shifter that attaches to the shifter lever..
a pedal, bracket and a new clutch cable...
easy installation...
If you have any specific questions... let me know...
Old Jun 24, 2009 | 06:41 PM
Burzum's Avatar
Burzum
6th Gear
thanks all, yea found all the info i need, ill give rick a call and keep you posted
Old Jun 24, 2009 | 07:57 PM
Ole Coyote's Avatar
Ole Coyote
It's a simple switch over. Go for it.
Coyote
Old Jun 24, 2009 | 08:28 PM
Burzum's Avatar
Burzum
6th Gear
ok i was at the la shifter site and it said 07-later softail with floorboards kit, do i want the straight, offset, threaded handle or regular handle? i really want a tank shift not a true suicide, guys that did this, what do you recommend?
so you know my bike is stock around the trans besides the v&h shortshots
Old Jun 24, 2009 | 10:27 PM
Cheesecake's Avatar
Cheesecake
Thumbs up
.... the clutch is the "suicide".... the shifter can be a jockey or tank....
as far as what one to go with... it depends on what "look" your going for..
I wanted a little "hot rod" look so I went with an extended tank shifter
as far as ordering... if your going to get the LA... just tell Rick what bike you have and what you want and he'll set you up with the right stuff...
Old Jun 24, 2009 | 11:05 PM
TRacer's Avatar
TRacer
I have both a police shifter mounted by the tank and the jockey lever that came with the LaBriola kit. Each has their own linkage and dedicated hardware so I can quickly swap shifters; I usually swap them once a month just for the heck of it. Here are two pics of the bike; the first is with the police shifter and the other has the LAJockey lever. For long solo rides I prefer the behind-the-leg lever, for riding 2-up I like the police shifter.
Attached Thumbnails XB jockey shift conversion-lowereddsssig.jpg   XB jockey shift conversion-bike-060609cc.jpg
Old Jun 25, 2009 | 11:40 PM
Burzum's Avatar
Burzum
6th Gear
one more question, how much in total besides blood sweat and tears did it cost for the labriola kit mounted for tank shift? thanks in advance
greenbax
Nov 25, 2014 09:47 AM
Johnny K
Aug 2, 2013 04:48 PM
WoodrowWillson
Mar 30, 2012 05:32 AM
stell55chevy
Shovelhead
18
Oct 28, 2009 09:46 AM
kingzy
Ironhead
Apr 30, 2006 10:14 PM
