doing mods myself, looking for tips and hints
Old Jun 27, 2009 | 10:28 AM
chunks's Avatar
chunks
Default doing mods myself, looking for tips and hints
Brand new 2009 Fat Boy.
Next weekend I'll be celebrating the 4th by putting V&H BSS, SE high performance air cleaner/breather, and a PC V on her.
I'm doing all the work myself. I've never done it before nor watched it being done.
I have a service manual, all the right tools, and a good mechanical mind.
Can pretty much figure anything out.
I also assume that all parts come with install instructions.
What I'm looking for is any tips, tricks, or gotchas that people just figure out on their own because they are not in the manual or instructions.
I'd prefer to not learn them the hard way if possible
These can pertain to removal of the stock parts as well as the installation of the new.
I'm already good with the PC V, so I'm pretty much just lookin for stuff on the exhaust and intake.
Thanks!
Here she is right now with the cosmetic upgrades done. Skull collection
mirrors, timer cover, air cleaner insert, derby cover (on the other side) gas cap medallion, and Kuryakyn ISO grips.
Old Jun 27, 2009 | 10:42 AM
DMJFatboy's Avatar
DMJFatboy
Just remember to pull the old exhaust gaskets out. I have done all of the mods on my bike by following instructions. This is my first harley. They are pretty easy to work on.
Attached Thumbnails doing mods myself, looking for tips and hints-010.jpg   doing mods myself, looking for tips and hints-009.jpg
Old Jun 27, 2009 | 11:07 AM
CSRflstc's Avatar
CSRflstc
If you've got the tools, the HD service manual for your model should be all you need for the mods you've listed. And this forum for advice if you get stuck!
I was hesitant to start my ape hanger swap, it looked like a lot of work. I read, looked at pictures, talked to people who had done it.... the job looked intimidating but was surprisingly simple once I tore into it.
The pride in doing it yourself and the knowledge gained is a great feeling. Just be careful with it and protect your paint and chrome! Good Luck!
Old Jun 27, 2009 | 12:40 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Working on these bikes is almost like working on a VW bug. Every things seems designed to be easily accessible and easily serviced without the need for stripping down half the bike to get to a small part or the need for piles of special tools.
These bikes are engineered well and with servicing ease in mind.
Lil' bit of understanding how tools work, a sewrvice manual and a good torque wrench is all you need to get yer' Mod On.
Get after it Bro!
Old Jun 27, 2009 | 04:16 PM
Xuallus's Avatar
Xuallus
nothing to it really, couple hours and she'll sound proper
few things you might need that you didn't mention: locktite, anti-seize and new exhaust gaskets... take your time and have fun
Old Jun 27, 2009 | 04:20 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Get new exhaust gaskets. Have a few extra flange nuts for the exhaust in case you lose one or two as I always manage to do. Take your time. Follow the instructions and take your time. Ask questions as you do it if you have any. Someone is always around here.
Old Jun 27, 2009 | 11:41 PM
Brianc9876's Avatar
Brianc9876
Goodluck sounds like you should be good to go. Loctite **** and have a good torque wrench
Old Jun 28, 2009 | 12:25 AM
Xuallus's Avatar
Xuallus
oh yeah, forgot to mention this - and I'm amazed no one else did either... WD-40 and dental floss to remove the reflectors
Old Jun 28, 2009 | 12:27 AM
ScReaMnEagLE22's Avatar
ScReaMnEagLE22
when doing the exhaust, are the heat shields installed along with the pipes or are hey installed afterwards ??
Oh yea, as for a good tip, use blue painters tape to mask off your frame and other parts that can get scratched in the process.
Old Jun 28, 2009 | 12:34 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Only "trick" I can think of is when your trying to replace the exhaust gaskets. See if your tool box has a small thin bladed screwdriver (I used a sharp metal scribe) you can use to pop or dig the old one out with.
They are made of a woven mesh steel impregnated with an asbestos like material. So getting them out is like pulling out a compressed steel wool ring.
Ideally you want to get it out in one piece so try putting the screwdriver in between the gasket and the wall of the exhaust port so you can collapse it to pull it out in one piece. But sometimes they don't want to come out all that easy and you wind up pulling out lots of little wire strings.
There also appears to be two different versions of the gasket. One is tapered for stock pipes and the other is square for aftermarket pipes.
Some places only carry one kind so your kind of stuck. But if they have both get the square one, it works better with aftermarket pipes.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
