03 Heritage Classic Cutting Out
Old Jun 29, 2009 | 04:25 PM
dazsa's Avatar
dazsa
6th Gear
Default 03 Heritage Classic Cutting Out
I have an 03 Heritage classic with 95 upgrade and the Thundermax on it. It usually runs fantastic. Over the last couple of days, when I am riding at any constant speed, the electronics go out and the motor stops for an instant and gets going again. When this happens the spedo and the tach go to zero and when the motor comes back they go back to the speed and rpm.
It only happens for a second, but it kind of freaks me out. I was wondering if it is the main "on" switch, Every once in a while, I will turn on the main switch and no lights or engine lights will come on. I can wiggle the switch and everything is fine.
Should I just change out that switch and if so, is it a DIY thing?
Thanks for any help.
Don
Old Jun 29, 2009 | 04:33 PM
128auto's Avatar
128auto
It could be the ignition switch, it happened to me a few times after I washed my bike, wiggled the switch and did the trick.
I would first verify the problem, when it happens again, try to wiggle the switch back and forth, see if you get power. The switch shouldn't be hard to change.
Old Jun 30, 2009 | 04:00 AM
oct1949's Avatar
oct1949
That could be it since it does the other also.
Old Jun 30, 2009 | 07:25 AM
dazsa's Avatar
dazsa
6th Gear
Thanks. I will see how much the replacement part will be and maybe just get it to have it on hand.
Don
Old Jun 30, 2009 | 10:26 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Also check your battery connections to the battery and the ground. This could cause this as well.
Old Jul 3, 2009 | 03:04 PM
dazsa's Avatar
dazsa
6th Gear
I tightened all of the connections and took apart the switch off the tank and cleaned everything and after riding for four days the problem has not returned...
THANKS to you guys that helped!
Don
Xtremerider112
Oct 10, 2014 09:24 AM
Mal74
Mar 23, 2011 09:30 PM
Ron2002
Dec 4, 2009 03:59 PM
ONLYTNT@YAHOO.COM
Sep 19, 2009 12:49 PM
deadman77
Aug 25, 2008 10:25 AM
