Quick thuner monster baffle question...
Old Jul 10, 2009 | 07:22 PM
anubisss's Avatar
anubisss
Default Quick thudner monster baffle question...
The thunder monster baffles I got do not have instructions (ebay). Do the lollipop side of the baffles face the rear of the pipe? That is the only thing that makes sense to me. the other question is how far back in the pipe should I put these. I am putting them in 36" fishtail straights. Thanks. Pics to come once they are mounted which should be tonight or tomorrow. One more question...should the round top part of the lollipop face up, down sideways, what? I have read that different angles give different results. Let me know how you did yours.
Old Jul 10, 2009 | 07:38 PM
WARG's Avatar
WARG
6 inches from end of pipe is where you drill your mounting hole. I can't remember where my lolipop was positioned. I know I drilled the hole on the inside sidewall of the pipe. Lollipop facing towards the rear of the bike. By the way, BCT has great customer support, so you can call them and they will give you the exact direction.
Old Jul 10, 2009 | 08:12 PM
anubisss's Avatar
anubisss
Thanks Warg. What did you use to get the hole started. I don't have a punch. Any other suggestions or should I just run to the hardware store?
Old Jul 10, 2009 | 08:53 PM
KumaRide's Avatar
KumaRide
A 16p nail can work or a large screw... Depending on the hole size, sometimes I start with a smaller drill size cause its easier to make sure the hole is in the right sport, then use the correct drill bit.
Old Jul 10, 2009 | 09:07 PM
anubisss's Avatar
anubisss
Okay. I used a small screwdriver that was rather sharp and that worked fine. Baffles are mounted in the pipes. Quite a bit easier to do than I would expect. Next to put them on the bike.
Old Jul 10, 2009 | 09:13 PM
anubisss's Avatar
anubisss
Are P clamps strong enough to bend at a 90* angle? Anyone know? This is what I pan to do to mount the pipes, but I do not want to snap the clamps.
Old Jul 10, 2009 | 09:35 PM
m i k e's Avatar
m i k e
i put mine 3" from end bike runs great
i actually have less decel popping than w/ stock baffels
sound good eh??
toastman
Apr 30, 2011 11:56 AM
locodude
Aug 30, 2010 08:19 AM
phat96
May 17, 2008 11:07 AM
Doug45601
Jan 26, 2008 05:44 PM
relli
Nov 5, 2007 06:51 AM
