Come on....NOBODY has this part?
Old Jul 14, 2009 | 12:17 PM
FLYING_BURRITO_BROTHER's Avatar
NOT A MODERATOR
Default Come on....NOBODY has this part?
Why hasn't some aftermarket company created a replacement panel for the back of the bobtail fender that eliminates the license plate hang down?
They'd make a fortune.
I see some people have modified/cut the plate bracket off...but that seems a bit Mickey Moused (no offense to yous who've done it)....mostly it's because I'm not that skilled with a Dremel.
Old Jul 14, 2009 | 03:42 PM
hogdiver96's Avatar
hogdiver96
this could be a good thread but what the hell are you talking about ???
Do you mean the licence plate bracket ? if so then the HD tri bar light gives you the option to eliminte that.
i often thought haw cool a filler would be to go in the bob tail and then have a side mount plate (is that wot you mean ? )
Old Jul 14, 2009 | 03:59 PM
NOT A MODERATOR
Yes...the huge @ss hang down factory license plate bracket needs to go.
I don't want to add the LED tri bar piece and it looks funky with the plate bracket removed anyway (from pics I've seen).
I just can't believe a company has not created a replacement tail light housing/panel with eliminated plate bracket. Seems like such an easy thing to do and plenty of people have asked this question before me.
Old Jul 14, 2009 | 04:28 PM
96black&blue's Avatar
96black&blue
i put a cats eye in but yes,the plate still hangs down..if not side mount where else would you put it.might not be as bad if i changed inspection sticker plate
Attached Thumbnails Come on....NOBODY has this part?-141.jpg   Come on....NOBODY has this part?-142.jpg
Old Jul 14, 2009 | 04:44 PM
GunmetalBlueNT's Avatar
GunmetalBlueNT
just remove the liceense plate bracket altogether and get a side mounted plate holder, looks better anyway.
Old Jul 14, 2009 | 04:46 PM
NOT A MODERATOR
My plan is to go side mount off the axle.
I guess I'm gonna have to take it to a shop that can cut it right and refinish it.
Old Jul 14, 2009 | 04:49 PM
NOT A MODERATOR
The license plate bracket is part of the tail light housing. Are you saying to remove the whole assembly? This would eliminate the tail light and leave a huge opening under the bob tail.
Old Jul 14, 2009 | 04:52 PM
GunmetalBlueNT
put in a more streamlined tail light, that doesnt use the obnoxious bracket and relocate the license plate with a side mounted unit.
Old Jul 14, 2009 | 04:56 PM
NOT A MODERATOR
Other than the LED Tri one (which I don't want to use and looks funny with the plate bracket removed), a new tail light housing without a license bracket does not exist.
Old Jul 14, 2009 | 04:57 PM
96black&blue
you could cut the plate part of the bracket off the catseye mount.you would only need a little white light for the side mount plate. hhmmmmm. dammit you got me thinkin bout another mod.
