V&H FuelPak vs. Power Commander
Old Jul 15, 2009 | 01:03 PM
jeff.georgalas's Avatar
jeff.georgalas
I'm with nvsteve. I ordered my PCV from fuelmoto (a site sponsor here in case you didn't know), and he pre-programmed it for my specific set-up. He asked what kind of pipes I was using and what kind of air cleaner. I told him, he programmed it before he shipped it to me, and it runs beautifully. His customer service is exceptional as well.
Old Jul 15, 2009 | 08:05 PM
jed1069's Avatar
jed1069
Well let's see:
How serious are you about tuning?
If you just want to add pipes and a/c and make the bike run right Fuelpak will be just fine. Easy to change maps my friend has one on his sporty.
If you are looking at doing future mods ie cams, headwork, etc... the PC has much more ability to tune. I have a PC-V on my fatboy I ordered it from fuelmoto.com great service. If you do mods he can email you a map and just plug your laptop to update map. Or if you want to get serous about getting every last hp out of your motor you can take to a dyno and fine tune. You can not do this with the fuelpak. Hope this helps.
Old Jul 15, 2009 | 09:16 PM
Brianc9876's Avatar
Brianc9876
I would go with the PC for the versatility, I know the FuelPack is decent but in my opinion it is entry level fuel management, go with the PC if those are your only two options. Otherwise I would say Thundermax with Autotune or the TTS!
Old Jul 15, 2009 | 10:16 PM
Mrawsome21's Avatar
Mrawsome21
Thanks for all the tips. It looks like I'll probably be going with the PC. Prices I saw in J&P had the FuelPak a little cheaper than the PC, but I didn't realize it was as limited in it's usefulness. With the prices from FuelMoto and the ability to adjust in the future, looks like PC is the definite winner.
Old Jul 15, 2009 | 10:20 PM
RocketRocker's Avatar
RocketRocker
I have a FuelPak on my Rocker with BR's and V&H Vo2 and it sucks....I will be going with something different. FuelPak runs to lean and cannot be used to make any fuel/air adjustments during the dyno tuning at each RPM range. If you do get the thing you will experience backfiring as mentioned before and I would call them to get all of codes to punch in...do not trust the website or the photocopied pages that come with it (they both give different codes). Good Luck.
Old Jul 15, 2009 | 10:28 PM
Joe What's Avatar
Joe What
Go with the PC-V,if you have extra coins that you want to spend then go with the Thundermax...IMHO
Old Jul 16, 2009 | 07:45 AM
tk353's Avatar
tk353
i had the pciii and a dyno tune because my bike would not work with canned map. it worked great but then i changed pipes and did not want to pay for a dyno tune again so i found a used thundermax with auto tune for $450 and sold the pciii for 150. i love the thundermax with auto tune.
Old Jul 16, 2009 | 01:22 PM
rdoucet's Avatar
rdoucet
If you can wait a while and get some more money (or money isn't an issue) then I would go with the ThunderMax with AutoTune. I had the fuel pack on my bike and a switched to the ThunderMax after reading reviews for quite a while - all I can say is that it works great with my bike especially when running the closed loop system. I installed this on a 2002 Night Train with Vance & Hines short shot pipes and a S&S high flow air cleaner.
Old Jul 17, 2009 | 01:19 PM
ITZ4me515's Avatar
ITZ4me515
PC5. I've got 2 buddies that have it & love it...plus you can get the auto tune module for it too for way less than the Thundermax.
Old Jul 17, 2009 | 02:15 PM
cammy5477's Avatar
cammy5477
Originally Posted by cammy5477
have a fuelpak on just now but it makes my bike backfire a little on decel. i am going to buy a thundermax with autotune i hear they are the crem de la crem of ecu tuning
after reading this thread and posting i thought to myself im going to see if i can get a better code and give it a try. id never questioned the first code before cause the dealer put it in but when i stuck my code in from the v&h website the bike is now night and day better and rarely backfires on decel so thank you mrawsome for spuring me on to look for a code.
just shows you cant trust the stealers to give a **** about your bike once they have your $Ł
