installing thundermax / autotune
Old Aug 26, 2009 | 09:25 PM
Cheesecake's Avatar
Cheesecake
Originally Posted by cammy5477
i have lost my mileage range on my speedo
Cammy sorry I got in late on this one... but it looks like you have everything under control!
I have heard rumors about the DTE firmware upgrade... but as of yet I have not seen anything....
I have always used a trip meter to keep an eye on the gas situation...
Since installing the TMax... my mileage has suffered a bit... so be on the watch!
CC
Old Aug 27, 2009 | 06:23 AM
cammy5477's Avatar
cammy5477
CC
no problem paul
randy from tech said they were continuing to find a solution but none as yet.
i will be doing as you do and using my trip meter from now on but i thought it was supossed to help gas mileage? do you feel your bike runs cooler or what major advantages have you noticed
Old Aug 27, 2009 | 06:57 AM
walterwindbag's Avatar
walterwindbag
Cammy Hi. I have some questions.
1/ Do you have the resistor/blanker/gizmo things on your muffler and intake connections to prevent any error codes throwing up?
2/ What kind of gas mileage were you getting before? I get around 45 mpg locally (christian units, not these shortweight US galleons) with just slip-ons on.
All the best with the fitting and running. I have been reading about TM with auto-tune for the last few years and it sounds the bollocks to me.
walt
Old Aug 27, 2009 | 07:36 AM
rbabos's Avatar
rbabos
All of the tmax maps that I've looked at are rich at cruise rpms, which will kill mpg some. Fortunately you can edit in some leaner mixtures where you need them and reclaim it. Plus keep it running cool in traffic at the same time.
Look at the maps as a basic setting only. Since no two bikes are the same, or riding styles it's best to run it , change areas where improvement is needed, or desired. You can get the best of both worlds with a bit of playing with it.
Ron
Old Aug 27, 2009 | 08:15 AM
Mark g's Avatar
Mark g
did what you said and watched video mark......what a great vid
bike is running awesome now..... spoke to randy at thundermax tech and man that guy gets back to you quick usually within minutes.....great product great service only one thing though....i have lost my mileage range on my speedo for now im sure with future firmware updates they will fix this.
thanks again mark you were a great help with this dude.
Glad I could help.
on the gas mileage, after doing some riding write your learned offsets to your base map, then reload and initialize the saved map. the system is only allowed to change by 20% . each time you save and reload it can learn another 20%. Your milage will come up each time you do this.
As you've seen Zipper's is always there to help as well. they are big on customer service.
Old Aug 27, 2009 | 08:45 AM
cammy5477's Avatar
cammy5477
walt
hey walt
i havent done anything to the pipes at all apart from take of the stock sensors and replace with the thundermax sensors. there are no error codes showing initialy the engine management light was on but turns out i had a cable unpluged (DOHH).
as for gas mileage.....to be honest im not sure of figures which sounds dumb but i filled it up and rode the thing then filled it up again.
i will take note and get back to you dude im going to thunder in the glen on saturday which is about 200-300 mile trip for me so i will know better then.
Old Aug 28, 2009 | 06:55 AM
walterwindbag
Have a good one. I got back 2 weeks ago from my 'local' club rally in Leopoldsburg, Belgium. About 2,300 miles over the 8 days.
Stay in touch.
Walt
Attached Thumbnails installing thundermax / autotune-woodsiders.jpg
Old Aug 28, 2009 | 07:24 AM
rbabos's Avatar
rbabos
Originally Posted by Mark g
Glad I could help.
No need to reload the map. Writing the offsets makes a new map and continues from that point, but only to limitations of the afr maps. I don't have time for this nonsense, since it takes quite a while to create the initial offsets within the whole rpm range. Moving the blocks first to get the immediate results with later offest writing once you are happy with the map is faster. While writing offsets refines the existing map, you can't reach 14.2 for cruising afrs without first moving the blocks. Reference is required to create the offsets that will be later written if chosen to do so. At least, that's how I see it.
Ron
alee18
Apr 29, 2014 09:01 AM
vtwinbmx
Mar 23, 2009 07:06 AM
MJStephens
Jun 6, 2008 09:43 AM
ubreal
Oct 17, 2007 09:39 PM
stro1965
Jun 11, 2007 11:22 PM
